Starting Problems
Starting Problems
Iv got some problems starting my Carson 'wild cat' with a 3.5ccm force motor. These are supposed to be easy to handel, been a pain in the ass for me tho.
Its been about 1 year since last time I drove it. I just started it up a few days ago after a lot of hassle. I bought some more fuel and a new ignitor, and since
then I have not been able to get it going. :S I got all the motor adjustments set to standard. The car will only start for a moment or just drive by itself for a lil while,
but when I moce the throttle it stops. o_0 Anyone got an idea of whats wrong? I just cant seem to find it out. Iv been trying for several hours - no luck.
Any help would be great.
RE: Starting Problems
Have you tried lettin it warm up for a couple of minutes before squeezing the the throttle trigger?
Also try setting the throttle trims back to neutral and make sure all your batteries are charged up.
You may have dry o-rings or seals. How did you store the engine? Did you go through it with after-run before you let it sit? Did you do a tear down before starting it and check your gaskets and o-rings? Could be any number of things causing your problem.
Yeah, iv tried letting it warm up. Im not really that much into rc cars... didnt do anything special before putting it away.
But its kinda strange when it did run so smooth just 2 days ago, and now it refuses. Can it also be just a few adjustments?
