HELP!! are these servos good enuf?
i bought a hanger 9 CAP 1/4 scale the 73" wing one.. right now it has a 1.08 in it but ijn the future ill go with a 1.60 i dont know if my setup is safe enough right now..
I have 2 airtronics 94732 servos in the wing i dont know the tork on them would you guys?
I have only 1 94161 Large-Scale Servo puttin out 115 / 144 (i dont know why airtronixs says it like that) but will only 1 large scale servo like that work for a 1.60 up there doing heavy stuff?
and last i have a 94102 heavy duty on the rudder look like its only puttin 42 / 53 torque i think ill be changing this one.
well i do plan on mean menuevers could you reccomend what i should do on setups for servos? thanks guys -danboy
My Feedback: (506)
Specs.
94732s are coreless, dual-ballraced, 68 oz-in of torque @ 4.8v, .19 sec/60 degrees. These will do fine on your ailerons.
The 94161 would be a good choice for your bird's rudder.
Reserve the 94102 for the throttle.
Lots of people use dual elevator servos on these, mounted in the fuse. Futaba 9001 (or similar) are good for this application.
thank you much visioneer ill slap that elevator servo on the rudder and should i mount the to elevator servos to the tail? if so how would i do this just make 2 plates? thnks bro -dan
