JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Continuous Beep From Engine
Old 07-16-2002, 03:25 AM
KevinBarr
My Feedback: (27)
Default Continuous Beep From Engine
Question. I was running my new P-120 and after an auto shut down, I had a continuous beeping coming from the engine, not from the ECU.
First off, am I hearing things? or is this really coming from the ECU and not the engine ( I am positive it came from the engine)
Second, What is this notifying me of, I could not find anything in the manual concerning this...
Kevin
Old 07-16-2002, 04:06 AM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Default Hi Kevin
Not sure what a continuous beep means, but all of the sounds from the system do come from the motor (like the beeps you hear before startup)
Do you remember what the LEDs were doing, if anything?
Regards
Old 07-16-2002, 12:50 PM
KevinBarr
My Feedback: (27)
Default Beeps
Matt,
Its the same beeps as the start up beeps, but just a steady "beep-beep-beep".
Whan you say " all beeps come from the motor". Are you saying that the ECU does not generate the tones?
At the time of the beeping, none of the LED's were lit..
Thnaks for the help, I will give JETCAT a call...
Kevin
Old 07-16-2002, 06:19 PM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Default Hi Kevin
Ok, you heard a series of beeps, not a continuous tone, that is good.........and yes, the "motor" generates the tones :-)
When you were starting did you notice that all of the LEDs were working (the "chase" was correct, and the green LED was flashing during the sequence?
Old 07-16-2002, 09:05 PM
KevinBarr
My Feedback: (27)
Default Reply
Matt,
The sequence was working. Before I advanced the thrrottle to start, the LEDs were doing the Green-Red-Yellow dance.
And when it was starting, each LED was lighting to represent the respective stage of starting.
I just ran the engine a few more times and did not get the beeps???
Maybe I am going loony, to much Kero Fumes
Kevin
Old 07-16-2002, 11:33 PM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Default I will still investigate and get back to you
about the beep, I have never heard it, and if the motor runs I would just keep enjoying it!
Old 07-17-2002, 01:40 AM
KevinBarr
My Feedback: (27)
Default Thanks
Matt,
I have three years on my AMT's. Been great engines but wanted to try soemthing new. I think the JetCat will prove just as reliable. I have been pleased so far...I can't wait to get this second Eagle airborn and ready for the Missouri Valley jet rally...
Thanks for the feed back...
Kevin
Old 07-17-2002, 01:51 AM
Bob_Wilcox
If you have a version 4.0 ECU and unplug the I/O board and GSU, it will continuously beep. Also, if the Glow head is bad, it will beep but the red LED will flash as well. Sometimes hard to see!
Old 07-23-2002, 08:45 AM
CobraJet
CobraJet's Avatar
I also got the continous "beep". It was telling me the plug was burned out. Happened after I bumped the plug voltage up .1-.2 volts. It was already set at the maximum for the type plug I was using...
