Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car General Discussions
slight fuel build up near cooling head
Old 08-26-2004, 06:46 AM
nitroarcher
nitroarcher's Avatar
Default slight fuel build up near cooling head
Just noticed this but after racing my car round a bit there is a slight build up of fuel appearing, see pic below, what could be causing this.
Old 08-26-2004, 08:39 AM
redheat8
Default RE: slight fuel build up near cooling head
Look for the following; check the heat sink and shim that fits between the block and heat sink, exhaust port or were the exhaust connects to the motor gasket could be shot, carb. to manifold fit ,is it tight and do you have a good seal in that area? RED
Old 08-26-2004, 08:44 AM
nitroarcher
All that seems ok, it cant be nothing serious as the car runs fine and if there was air leaks the car would not run correctly am i right in saying this RED
Old 08-26-2004, 08:50 AM
redheat8
You are correct, could be a minor leak in the hose,hard to say with out taking a closer look at it, I would just watch it closely to make sure that it does not turn in to a big problem, RED
Old 08-26-2004, 09:01 AM
nitroarcher
will do, cheers RED
Old 08-26-2004, 10:15 AM
redheat8
Good Luck , hope the weather clears up for you, RED
Old 08-26-2004, 10:27 AM
MAX-ST
when the engine floods, the excess gas leaks out of the cooling head right? so maybe the fuel mixture is too rich. but i many be wrong
Old 08-26-2004, 10:32 AM
redheat8
If the heat sink bolts were loose I could see that happen , good point tho, RED
Old 09-06-2004, 07:37 AM
Bluebrew
Bluebrew's Avatar
I always end up with a mess in that area if the glo plug is loose or the plug seal is shot or missing.
Old 09-06-2004, 08:57 AM
redheat8
That would be enough to cause a loss of compression also, RED
