Engine cuts out
Old 08-31-2004, 05:04 AM
superspeedy
Default Engine cuts out
when i first start my car up and rev it, it doesnt move anywhere it just cuts out.[:@]i have to start it about 10 times before it will run normally.[:@]
is this normal.
one more thing,
how do i know which glow plug to buy for my car.
it is a cx-15 engine (.15)
thanks
Old 08-31-2004, 11:40 AM
Nitrofreak_105
Nitrofreak_105's Avatar
Default RE: Engine cuts out
try revving it a few times with starter in
Old 08-31-2004, 11:48 AM
superspeedy
ok thanks ill try that
Old 08-31-2004, 03:52 PM
redheat8
Check the slipper and the clutch bell ., clutch shoes, sounds like the clutch is not engaging properly, RED
Old 08-31-2004, 10:19 PM
vwcalbug
Try redoing your carb settings, check glow plug. Could be too righ, or to lean...if its abrupt, then im guessing lean...if it bogs down, too rich. Other then that glow plug is best bet, take it out, and put it in the starter. - Justin
Old 09-01-2004, 03:11 AM
superspeedy
ill check the clutch but i think that is working ok
my car wont idle for more than 5 seconds either. its really annoying as i have to keep reving it to keep it going.
should it be leaner or richer.
if it helps, when it stalls the engine sounds as if the pitch is going upwards (if that makes any sense)
Old 09-01-2004, 04:25 AM
drevil
I haven't screwed with nitro motors in a long time so i could be wrong but it sounds like either the idle set screw is set so the carb closes too much. (too low of an idle) or the low speed needle is set too lean.
It's kind of trial and error so you might want to trial those things and see if it helps at all.
As for glow plugs the rule of thumb is "when in doubt, swap it out". I've lost count of how many times i've pulled and pulled and pulled that stupid pullstarter to finally figure out that the glow plug was going bad....argh!
Mike
