servo buzz
Old 04-21-2005, 11:35 AM
mickeeand
Default servo buzz
Folks I have a ?
Is servo buzz ok? I have a throttle servo that buzzes when its closed and not when its open?
thanks.
mike
Old 04-21-2005, 12:19 PM
Rodney
Default RE: servo buzz
Sounds like you need to adjust the endpoint either mechanically or electically if your transmitter permits EPA. Most probably you servo is being stalled out at one end and keeps trying to move farther than it mechanically can. This is very hard on the servo and also will run down your battery much faster than normal. It is important that you eliminate this problem befor flying.
Old 04-21-2005, 05:55 PM
RC-Captain
RC-Captain's Avatar
Took me some time but I found out the EPA setting can be your best friend , especially on the throttle control.
More info.
Keep in mind there is a negative and positive setting for each channel that uses the EPA program.
Old 04-22-2005, 07:11 AM
MinnFlyer
MinnFlyer's Avatar
Yes, if the throttle has reached the end and the servo is still trying to pull it a little further, you should adjust that.
However, if a slight "Jiggle" of the throttle pushrod will stop the buzzing, then once the engine is running, the vibrations will do the same.
Old 04-22-2005, 09:14 AM
Richard L.
My Feedback: (24)
Richard L.'s Avatar
Sometimes side force will also cause the servo to buzz, especially if the pushrod is not perfectly lined up with the hole in the servo arm. I like to use flexible braided cable for the throttle since the cable can bend a little and not put extra pressure on the servo arm.
Old 04-22-2005, 03:24 PM
mickeeand
thanks guys, your a big help once again!
mike
Old 04-22-2005, 05:29 PM
RC-Captain
RC-Captain's Avatar
braided cable
Are you talking about 'guide wire' ?
Old 04-22-2005, 05:34 PM
Richard L.
My Feedback: (24)
Richard L.'s Avatar
I'm talking about flexible steel braided cable inside a nylon sleeve, such as Dubro flex cable:
Old 04-23-2005, 11:39 AM
Rodney
Excellent pictures Richard L. What camera and technique are you using?
Old 04-23-2005, 11:48 AM
RC-Captain
RC-Captain's Avatar
YES ! [X(] I would have never thought about using it for a push rod. For what I normally use it for it is called guid wire and go you to 3-4 inches in diameter, Nice technique. You should post a new thread in this forum.
Old 04-23-2005, 05:54 PM
Richard L.
My Feedback: (24)
Richard L.'s Avatar
Rodney, I'm using a Nikon Coolpix 4500 digital camera. One half of the camera can swivel at any angle, making taking pictures in tight spot a breeze. It's a gem of a camera. Too bad Nikon doesn't make this particular model anymore.
ID:	261995   Click image for larger version
ID:	261996   Click image for larger version
