Hey I raly need help quick, I want 2 get started, Pull start problemPLEASE
Well thanks 4 lookin, I got a Nitro RS4 2 here, i pulled the pull start and it stayed out, how do i get it back in without bying a new 1, I dont think the coil is broke. If you dont under stand ths, I explained it better on pg 1. Thanks... Vincent
well i used to just unscrew a couple of screws and wedge a flat head inbetween the pull starter and the backplate and it would just zip back up and then of course i would put it back together, but then again the only reason why i did that was because my pull starter was so annoying and it would get stuck if you pulled it a inch or if you pulled it 10, it didnt really matter. and by the way if you try to do it this way dont stick the flat head in to far
