Wobbly left rear tire
Old 06-01-2006, 09:03 PM
Racktacular
Default Wobbly left rear tire
I just picked up my first RC (RTR BTW) and while doing engine break-in, I notice that the left rear tire is wobbly but the right rear is fine.
What could be the problem and what is the solution?
Old 06-01-2006, 09:18 PM
ryan_t888
ryan_t888's Avatar
Default RE: Wobbly left rear tire
Is the tire snugged up? Does the axle appear to be bent? Is the tire properly glued? Are the bearings/bushings properly seated?
Ryan
Old 06-01-2006, 09:30 PM
Dawman
My Feedback: (33)
Check all those mentioned ^ . Also possible you bent the rim or if the wheel nut is/was loose could have oblonged the hole in the rim .
Old 06-01-2006, 11:06 PM
Racktacular
The car was straight out of the box like that. I'm such a noob that I have no idea how to look for any of those issues. Any advice anyone can give me.
Old 06-01-2006, 11:12 PM
Racktacular
Oh and one more thing that could be helpful. The instructions told me to check/adjust the diff before first use. I looked and the directions on how to do that but it was over my head. I had no idea how to do that, so I just didn't do it. Could that be the problem? If so is there good step by step directions availble somewhere on the net that is better than the instruction booklets?
Old 06-01-2006, 11:13 PM
Dawman
My Feedback: (33)
What do you have ?
Old 06-01-2006, 11:21 PM
Racktacular
I have the Team Losi XXX-T Sport Brushless RTR
Old 06-02-2006, 12:49 AM
Racktacular
I figured out how to check the diff. It seemed fine as the left rear tire was hard to turn when I held the right rear tire and the spur. So no adjustment needed to be made there. I didn't glue the tires and they seem to be nice and secure in place all the way around. Not sure what the issue is. I figure I'll stop by the hobby shop where I bought it and have them figure it out
Old 06-02-2006, 08:04 AM
drummin82
It's probably the lug nut on the wheel was loose. This is the nut that holds the wheel on. Make sure that it's nice and snug. Mine was loose straight out of the box as well.
Old 06-02-2006, 08:50 AM
Dawman
My Feedback: (33)
ORIGINAL: Racktacular
You will have to glue the tires on , well they should already be glued if it`s a RTR .
