Eurokit's hydraulic gear info needed
Old 08-10-2006, 06:27 AM
Rider-60
My Feedback: (17)
Default Eurokit's hydraulic gear info needed
Hi
Is there anyone using this system?
is it reliable , is it heavy? what is your feedback?
Florent
Old 08-10-2006, 08:07 AM
mick15
mick15's Avatar
Default RE: Eurokit's hydraulic gear info needed
hi florent, no not in a jet but in a 3w bearcat, for me the system is brilliant, simple, easy to use and not that heavy.
mick
Old 12-22-2006, 12:55 PM
g_boxwood
g_boxwood's Avatar
Hi mick!
Just wanted to ask you a few more infos about your setup.
- is the operating time more realistic than with a pneumatic system? IOW, how long does it take to move the gear up and down? With what voltage?
- have you ever experienced any leakage while storing the model? That could become boring... and mess things up!
- did you remove the spring inside the cylinders?
I already own EK professional line retracts that I'm air-operating and I'd really like to upgrade to the hyd system.
Thank you!
Old 12-22-2006, 03:54 PM
mick15
mick15's Avatar
Hi Giacomo
Yes the speed is realistic arround five seconds UP and DOWN.
No had no leaks, though for this model I made my own retracts with 3/4" cylinders.
You will have to use 4mm oil lines right through, so the u/c units will probably need modifying.
And finaly you cannot use spring down they must be oil up and down.
Hope this helps.
M
