Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
chrome moneykote
Old 01-11-2003, 09:59 PM
tim thompson
Default chrome moneykote
I finished my wing b-25 in chrome monokote with invasion stripes. Antenna is routed in fuse thru a nyrod about 4 inches protrudes out the back. Am I going to get interference? Taxi tests showed none.
Old 01-12-2003, 07:13 AM
nchrome
Tim don't worry about the chrome monokote I've been useing the stuff for quite a while and it woun't interfear with the signal of your plane. I just finished my wing B-25 and she came out just fine for me of course I did quite a few thing different than the plans(mechanical brakes,micro servoes for the flaps, working air coolers flaps. HS 81 micro servos for the rudders and my own pilots and copilots and gunners). If I get a chance to send you a photo I will send it to you. This spring will be its maiden flite which I am looking forward to. Good luck with your plane and if you get a chance send a picture or two to me
Old 01-20-2003, 05:38 PM
Mendes
Mendes's Avatar
I have a Sig Kobra covered in chrome with the antenna routed inside. It didn't get past the range check. I ended up running it out the fuse side and up to the tail, it worked fine then.
So be sure to range check!!!
