carb gap settings
Old 01-08-2007, 07:45 PM
camaro 69
Default carb gap settings
fairly new to the rc world.bought a savage x.what I would like to know is about the carb settings.the manual shows a 1mm gap between the carb bowl and slide.Is this with all radio equiptment on ?my carb shows no gap.which screw do I use to get this gap set.thanks
Old 01-09-2007, 05:43 PM
JohnnyReptile
JohnnyReptile's Avatar
Default RE: carb gap settings
First you want to reset everything back to stock. You want there to be about a 1mm to 2mm gap. then you can continue with break in or retune from there. I would suggest going to the HPI MONSTER TRUCK FORUM. Browse around there and you will find all kinds of good info. Good Luck.
