Fei Bao f-15
Fei Bao f-15
I just wanted to know what type of expierences you all have had with this jet, Quality, price, construction, and flight. I have done a search and have found not much on the f-15 but tons on the f-18 which i have no desire. please be forthwith the information you have Thank you
My Feedback: (27)
RE: Fei Bao f-15
The FB F-15 does not have ball bearing elevators. It is just like the Skymaster kit. It also does not have carbon spars, but the same as Skymaster. It's the same jet, with much better paint.
Beave
Beave
ORIGINAL: ravill
It is an upgraded SM F-15. It will have carbon spars, titanium elevator rods and an aluminum/ball bearing elevator mechanism. Exact same CG and throws. It'll fly great with a P-80 and be even more fun with a P-120.
Buy it, you'll like it.
Raf
Raf
RE: Fei Bao f-15
Don't be so quick on that...
ORIGINAL: bevar
Beave
Beave
ORIGINAL: ravill
Raf
Raf
My Feedback: (27)
RE: Fei Bao f-15
Rav,
I held one in my hands last month, right out of the box. It had sleeve elevators and flat aluminum spars. It also had the best paint work I have ever seen on an ARF. Drop dead gorgeous it was. Maybe the new ones will be different, but as of a couple of weeks ago, it is not.
What more would you like to know?
Beave
Beave
ORIGINAL: ravill
ORIGINAL: bevar
Beave
Beave
ORIGINAL: ravill
Raf
Raf
RE: Fei Bao f-15
Here is a link of a Fei Bao F-15 I am building that will be PST1300 powered.
[link]http://www.rcuniverse.com/forum/m_5166697/anchors_5166697/mpage_1/key_feibao%252Cf%252D15/anchor/tm.htm#5166697[/link]
Kit was very good to build and will be ready to fly soon.
cheers Pete
cheers Pete
RE: Fei Bao f-15
I love the look of that JADF f-15, I may have to go for one, i was really a toss up between the skymaster 1/8 f-16, I was leaning towards the f-16 because it looked more agile in the air, all the f-15 video i have seen it just great big beautifull sweeping manuvers, if i am wrong please correct me. are you pleased with the aircraft Powergrunt?
RE: Fei Bao f-15
ORIGINAL: Gidusko
Also some of the holes in the Rudders, Flaps and Ailerons for the hinges needed to be squared up so that the control hinge was smooth.
The elevator pivots, Rudders, wing ect are a nice fit and was a case of just screwing it all together once I had the horns ane servos installed.
Took me about a day to install the doors, air cylinders and get it all nice and neet so if you are not into fiddly jobs I would suggest going for the built version which has the doors, cylinders, horn slots ect all done.
Regards Pete
My Feedback: (31)
KY
RE: Fei Bao f-15
I saw one guy say his doors were hinged and the cyllanders were installed on his bao F-18, are you saying that the F-15 or ALL of their ARF's come this way? That is worth a part of the price difference right there as i have been told some of the other Chinese arfs dont even come with gear door hinges. Russ
My Feedback: (99)
RE: Fei Bao f-15
Here is the quote that I rec'd from them for a F15. Gear door $ 80.00 - If you want to have the gear door, cylinders, hinges, retracts, fuel tanks, fuel line factory installed please ad $ 100.00
RE: Fei Bao f-15
ORIGINAL: J. Campbell
At the other end of the Fei Bao scale you may also order the completely factory finished model (less radio gear/engine) if desired with all formers installed with Hysol, control surfaces hinged and pre-slotted ready for control horn installation. All gear doors, speed brakes hinged and fitted along with air cylinders, retracts/wheels and brakes, tailpipe, hardware etc. as well as fuel cells installed and plumbed. And finally 'out of mould' painted, detailed and in many cases a weathered finish done by factory for you in a wide selection of colour scheme options.
The various levels of factory finish options are in addition to the basic 'kit' price and can be included at time of ordering....The top of the line FB finish options allow you to have model ready for flight within as little as one week. The FB kits/ARF's do not come from factory with instructions, regional reps can supply experienced jet modellers or first time jet builders with all the critical build and equipment selection information they may require. Photographic build and fitting out guides should become available soon from the Fei Bao dealer network this should cover most of the common FAQ's.
Hope this helps clear up some Fei Bao related questions for you and others...
Cheers- Marty
RE: Fei Bao f-15
Hey guys,
News from China now the Fei Bao F15 comes with new composite, carbon fiber wing spars and ball bearing elevator mech, this is a very good plane to fly and she is better now.
RE: Fei Bao f-15
ORIGINAL: rcjetmodels
Hey guys,
Hey guys,
Can you please advise if the carbon spars and ball bearings elevator will be implemented or same have already been and since when?
Thanks for your feedback.
Regards.
My Feedback: (99)
RE: Fei Bao f-15
I just received my FB F15 on Monday this week and it has carbon spars, I have not checked the ball bearing elevators yet. The out of the box quality looked good, paint work is good. As I've already built one of the Yellow F15's I can't imagine this one being any harder to assemble. I also paid the money to have the doors installed, well worth the money.
RE: Fei Bao f-15
ORIGINAL: extra 300
Wagner,
Regards.
Hey guys,
Hey guys,
Regards.
RE: Fei Bao f-15
ORIGINAL: Spiritwind
Hey guys, who's the dealer for Fei Bao in the US? Or is there one?? Would like to get a price..Thanks....
RE: Fei Bao f-15
I just received mine. It´s a beautifull plane, with great finish. And no doubt it´s a very good flyer.
I will post pics as soon as possible.
Regards.
Regards.
