Painting fiberglass
Painting fiberglass
I just tryed to paint my fiberglass cowl and bellypan and when i primed i got holes and pits and it looked like the waffeling of the glass was bleeding thru am i doing something wrong or is there a trick to it
Painting fiberglass
sounds like you have glass with a lot of pin holes. The first thing to do before priming is clean the glass, often there is still mold release on the glass. You can use acetone or similar to clean it up. This is also important as the paint may otherwise lift at a later stage. Priming will show up the pin holes. Fill the pin holes, there are a variety of light fillers available, in some cases stuff like model magic will work if the holes are very small, Bob Violet sells a pin hole filler, vinyl spackle will also work. after filling sand out the primer until the finish is smooth, If the weave is showing through this is likely to be the primer contouring to the weave. Sanding this out with around 400 grit will give a smooth finish. Shoot another coat of primer. This time the weave should not show through, if it does, sand again until smooth. At this point you should be fine.
Mike
Mike
Painting fiberglass
Try automotive paint products.Make sure you use epoxy primer
in fiberglass (it is the only primer that will stick).
Good luck...
Jay Cab
FinishMaster Tech rep
Miami,Florida
Good luck...
Jay Cab
Miami,Florida
