spur gear?
Old 05-22-2007, 12:51 PM
HpiDrifter420
Default spur gear?
i broke some teeth on my spur gear so i bought a steel spur gear and took off my gas tank. now heres my problem i cant pull the spur gear off b/c of the motor is in the way. what would be the easiest way to take it off?
Old 05-22-2007, 12:54 PM
Dorsil
Default RE: spur gear?
Remove the transmission and Simply take the bolt off the spur gear, and replace the pads if needed. take caution to not loose the 2 small washers between the nut and the Spur gear.
Old 05-22-2007, 02:13 PM
tommythecat
tommythecat's Avatar
Personally, I think pulling the motor is easier than pulling the tranny.
Old 05-22-2007, 02:55 PM
ymhhou
I pull the motor too, but could be just personal preference
Old 05-22-2007, 02:59 PM
HpiDrifter420
so if i wanted to pull the motor what all would need to be removed? just the bottom screws? does it come out as a whole or do i have to take one part off to get another off to get another off?
Old 05-22-2007, 03:01 PM
ymhhou
Just the four bottom screws, and the ground wire for your starter. I also losen the gas tank so I can swing it out of the way.
Old 05-22-2007, 03:05 PM
HpiDrifter420
ok thanks the gas tank is already off so now i just need to move the motor. thanks for the help
