Duralite digital switch
I received my duralite digital switch the other day and was in the process of hooking it up to the battery pack and I wasn't able to figure out which wires from the switch connected with the battery. One wire is blue and the other is red. Now on the battery the wires are black, red and white. Could someone please tell me what the blue wire should connect up with and the red wire also.
Tony
Tony
RE: Duralite digital switch
If you look at the switch, there should be 2 wires on one end and 1 on the other. The wire on the end with just 1 wire goes to the battery. The other 2 wires have different ends.One goes to the RX and the other is for charging. Mine's not a duralite, but it should be the same.
