Traxxas 550 12t Motor
Old 07-06-2007, 07:37 AM
kelly175
Default Traxxas 550 12t Motor
I keep burning up the 550 12T Motor can anyone help me find a different Motor to try. I am a heavy user and would like to have a much stronger thougher and more powerfull motor but I am also new at this. thanx
Old 07-06-2007, 11:52 AM
guver
My Feedback: (325)
Default RE: Traxxas 550 12t Motor
Try going UP in motor turns to a 19-23 turn 550. There should be lots of them very cheap, trouble is that it will have less power, not more. Possibly losing some gearing or voltage will help as well.
Old 07-06-2007, 01:22 PM
dirt101
I hate to say it but brushless is the way you should go. the way you say you keep burning up the stock motor it sound like you are buying a lot of them. at 28 bucks each it gets expensive. a mamba kit is 180 so that is like 6.3 titans so in the long run brushless is the way to go but if your not looking to spend that much you can get either a 18 or 19 tooth pinion, and hope for the best.
other things on brushless.
pros
theyre fast
no mataince at all.
theyre fast
you get an awsome esc with the mamba.
theyre fast
nothing wears in the motor besides bearing so if its not overheated it will last forever
did I mention theyre fast
cons
you still have to get a smaller pinion
price(over time it pays for itself so this is iffy)
tires start to get expensive
Old 07-06-2007, 03:29 PM
kelly175
Thanx everyone let me look into what you have said and see where im going from there.
Old 07-06-2007, 06:14 PM
twomanytoys
Get a modified 12t 540 can motor. A modified is muc more tolerant to heat, easy to rebuild or replace brushes and they are fast as heck. Much better than a 550 sealed can motor.
Old 07-06-2007, 07:30 PM
guver
My Feedback: (325)
A 12 turn motor would be a good choice for speed, make sure to use an esc that has a lower turn limit (12 turn for 540's) and to gear down too.
