spraying plane with polyurethane
NJ
I just wanted to know what the results were after you have done this. I am putting together a plane that recommends this to prevent the covering from wrinkling and peeling.
P.S. pics would be appreciated
CAP
CAP
RE: spraying plane with polyurethane
Waterbase polyurethane does not yellow with age, oil base polyurethane DOES YELLOW with age. The yellowing starts at about 6 - 8 months and is quite noticable on light colors.
WB Poly is fuel RESISTANT with the following caveats:
1. Let the poly dry for a MINIMUM of 7 days before exposing to glow fuel residue.
2. Do not let the exhaust residue remain on the finish for over 4 hours. After 4 hours the finish WILL soften.
I don't know what type of covering you are planing to use, however, I have not heard of ANY covering that says to coat with poly to "PREVENT WRINKLING AND/OR PEELING". I suggest using a decent quality covering such as Ultracote for a film and SolarTex for a fabric. It is suggested that SolarTex have a clear coat put on it. Solartex has a more open weave and the colored Solartex is fuel proof - the clear coat is to prevent staining of the fabric and to make cleaning easier.
NJ
I am jsut curious, maybe it will be benificial for me to paint or spray it on areas where the covering was trimmed and tacked onto the plane? Waiting seven days will be almost impossible.
I don't know what was used to cover the model.
How do I know whether my polyurethane is water based or not ? It is a clear gloss ACE brand.
My Feedback: (18)
It will say on the can water based poly. You can also look to see what you thin it with. If it thins with anything other than water in is not water based poly.
I cant imagine how wb poly would keep covering from wrinkling though.
If you use Ultracote check it with your paint first.
I have had Ultracote cause some types of paint to blister. Think it may have been acrylics but not sure.
Terry
Terry
AL
ORIGINAL: Redback
Terry
Terry
It would be helpful to know what kind of material we wish to coat in order to prevent "wrinkling and peeling".
jess
