ali woodie?
Old 10-17-2007, 02:48 AM
smiley_666
Default ali woodie?
hi everyone. ive got a question from my brother who's doing metalwork at school and wants to build a boat out of sheet aluminium using gas mono wood plans (he couldnt thinkof anything to make and saw me looking at plans ).
im just wondering if anyone has made any type out of ali? if so did it work?
Thanx, Thomas
Old 10-17-2007, 04:01 AM
martno1fan
martno1fan's Avatar
Default RE: ali woodie?
hi mate id say its a bad idea as it will be far too heavy but thats just my opinion.
Old 10-17-2007, 04:11 AM
bentley marshall
i dont think it would be heavy but welding thin ali is imposable and if you used thicker alli that you could weld that would prob make it heavy but weather it would be heaver that a wood one you will have to make it to fund out
but its worth a try would be an intersting project
keep us posted
Old 10-17-2007, 04:14 AM
martno1fan
martno1fan's Avatar
it will be heavier for the reasons you just mentioned if it was a good idea i think wed have seen a few built before now? .ive seen a few ali airboats built and they all ended up HEAVY!!.
Old 10-17-2007, 04:27 AM
bentley marshall
you could do it with out needing to weld anythng just use .5 or 1mm ali sheet and then use a cold weld type glue to bond it all together that would work i might try it my self one day when ive finished all my other projects
Old 10-17-2007, 04:31 AM
smiley_666
he said he'd rivit it all together apart from the bit of the hull in contact with the water, which he'd glue or something similar.
but i would think thin ali wouldnt weigh more than ply covered with epoxy
his idea, not mine
Old 10-17-2007, 04:33 AM
smiley_666
oh yea, he was talking about building it out of steel sheet, but i talked him out of that fairly quick
Old 10-17-2007, 04:53 AM
martno1fan
martno1fan's Avatar
it might work if its glued and he keeps the frames inside to a minimum,not sure about gluing ali its not my thing to be honest but one thing that could be a problem is dents .the rivets would look awfull though [:'(].
Old 10-17-2007, 05:01 AM
machine-it
i say go for it,
why not try something different then he can tell us if it works,
i dont see why thin ali sheet bonded together wouldn't work, they build real boats out of it.
i also thought about doing it from thin steel sheet if its well protected ie by powdercoating it would work.
just cos its different doesn't make it wrong (wait till you see mine the drive and rudder is nothing like anything ive seen but i like trying new stuff, it would be a dull world if everything was the same.
go on do it, [sm=thumbup.gif]
Old 10-17-2007, 05:09 AM
glennb2006
It could be joined by flush rivets, sealed at the time of rivetting then any protruding rivet flattened when the seal has gone off.
If the plate were thin enough the weight could be controlled. I am not convinced it will be any stronger than a good carbon / kevlar boat though.
Thinking on, a good aluminium welder should be able join thin sheet too.
Interesting.
Glenn
Old 10-17-2007, 06:04 AM
smiley_666
ORIGINAL: glennb2006
Interesting.
Glenn
he's not doing it for strength or anything, just as a metalwork project at school... and he still doesnt know if he's allowed to build it yet
i hope he does and gives it to me
Thomas
Old 10-17-2007, 06:50 AM
BMAD01
Interesting? Yes! Practical? NO! It will look good on the mantle. In the water??? Brian
Old 10-17-2007, 08:09 AM
machine-it
how about an alu airboat like this
http://cgi.ebay.com/REMOTE-CONTROL-R...QQcmdZViewItem
