Smart-Fly Engine cutoff Question
Hi Guys,
I just ordered two smat-fly engine cutoffs for my two giant scale gassers.
I was thinking about the cut-ffs and was wondering if using them negated the use of a manuall switch?
Battery - switch - cutoff - ignition
Battery - cutoff - ignition
Any response is appreciated
MR G
MR G
My Feedback: (27)
MI
RE: Smart-Fly Engine cutoff Question
I use them with out a switch -you just have to unplug your battery if your going to not fly for a day or two as there is a small parasitic current draw from the unit
or just put a switch between the cuttoff and battery
hope this helps
Frank
hope this helps
Frank
My Feedback: (45)
MI
ORIGINAL: MR G
Hi Guys,
MR G
Hi Guys,
MR G
What battery you going to use? Switches? Regulators?
My set-up starts and ends like this; 7.4v Li-on Battery goes to a Cermark On/Off Switch w/Charge Jack, which goes to a Regulator, which goes to the Smart-Fly Cut off Switch, which goes to your Ignition and Receiver. Lots of wires, worth the effort.
My Feedback: (54)
The Smart Fly Engine Cut Off is a failsafe way to ensure you can kill the motor if anything goes wrong. It will also kill the engine if you loose radio signal. Its a keeper in my book. I use a switch also so I can disconnect the battery from the ignition when not flying. If you don't use a separate switch, the Smart Fly will draw a little power all the time.
My Feedback: (198)
I use a switch but it is mounted on the inside of the plane. I turn it on when I put my plane together and shut it off when I go home. Robert, the owner of Smart Fly does not use a switch. The battery is mounted at the front of the hatch for easy access to unplug at the end of the day.
Either way is fine.
Either way is fine.
Thanks Guys,
Since I already have an ignition switch mounted, I will go ahead and keep the switch active and mount the cutoff between the switch and ignition.
Thanks for all of your input.
MR G
MR G
