Strange Motor/Radio problem lol
Old 11-26-2007, 05:03 AM
Calamari100
Default Strange Motor/Radio problem lol
When I use my stock motor, my radio works fine. When I use my modified 23 turn, my radio glitches a little. Strange huh? Could it be my motor?
Old 11-26-2007, 07:28 AM
happywing
happywing's Avatar
Default RE: Strange Motor/Radio problem lol
What motor/controller, etc. Some controllers require that the motor have capacitors. It would help to know what you have.
Old 11-26-2007, 08:00 AM
Calamari100
ok. Here we go.
Chassis - M-04M
ESC- Teu-101BK Tamiya
Radio - T2PHKA Futaba
Motor 1 (no glitching) - Stock Silver can
Motor 2 (glitching) - HPI R2 23 Turn
Reciever - FP-R122JE Futaba
Old 11-26-2007, 08:02 AM
Calamari100
NO WAY! Now I have this wierd thing that when i get on the throttle, the servo suddenly jerks one direction and then goes back to normal. and this happens EVERYTIME i accelerate from a standstill
AAAAHH HELP!
Old 11-26-2007, 08:30 AM
Jeckler
All radios require caps on the motor. Some are built into the endbell, most are soldered on externally.
Old 11-26-2007, 03:01 PM
BuzzBomber
BuzzBomber's Avatar
I think the TEU101 is only officially rated for a 27 turn motor. Is it possible that the ESC is dropping power to the receiver under the load of a 23 turn motor? If the motors are geared the same, the 23 turn will pull more current...
Old 11-27-2007, 09:36 AM
Calamari100
how do I know if my motor has a capacitor? what does it look like?
Old 11-27-2007, 09:51 AM
nitrosportsandrunner
nitrosportsandrunner's Avatar
here are some pics of my titan, the little round tan things are what their talking about. some times there are 2-3 of them. but like he said, many modified motors dont come with them installed, though the trinity motor i got had them included in the package. you should be able to get some from radio shack i would think.
your original motor should have them, if so, use that motor to figure out how to put ones on your modified motor. i did this and it worked for me.
good luck.
ID:	813312   Click image for larger version
Old 11-27-2007, 07:50 PM
Calamari100
what do they do anyway? Thanks for the advice every1
Old 11-27-2007, 07:57 PM
losi motor man
losi motor man's Avatar
stops a spike of amperage that may make other electronics on the rc go a lil bit crazy. its also known as a power leak . hope this helps you
Old 11-28-2007, 06:32 AM
Calamari100
can I buy capacitors seperately? and if so, how do I install them to my modified motor? Thanks for the advice so far everyone
Old 11-28-2007, 08:36 AM
boltech
boltech's Avatar
Yes you can. Any electronics shop or your LHS
http://www.rumrunnerracing.com/artic...capacitors.htm
