Carb Block Plastic type material?
Old 03-05-2008, 09:10 AM
altavillan
Default Carb Block Plastic type material?
4 questions;
What is it called? Where to get it?
Can you buy it in blocks large enough to make your own reed blocks from? Around 3" x3" x3".
Can it be milled?
Old 03-05-2008, 09:38 AM
soarrich
My Feedback: (98)
soarrich's Avatar
Default RE: Carb Block Plastic type material?
http://www.mcmaster.com/
search G-10
Old 03-05-2008, 10:09 AM
altavillan
Thanks Rich.
Old 03-05-2008, 10:50 AM
tim220225
tim220225's Avatar
No need to buy it 3 inches thick. Buy 3/8 to 1/2 inch thick at most. I bought 3/8X2X24. I also use Acetal on some and have had good luck with it. Either can be machined. The G10 and the Acetal drill and tap very well. I cut the material with a band saw then contour it with a belt sanding center machine.
