Hinge questions
AL
Hinge questions
I have a couple of hinge questions:
I hate to re-ask this, but a while back I got a recommendation for tape to be used on taped hinges (like on sailplanes and foamies), and I can't recall (or find the message here) the part number of the tape. It was a "3M Book Binding Tape", Cat No ???.
Second: a future project is a high-wing plane with an 80" wingspan and flaps about 2.5" wide and 14" long. The flaps are operated with single center servo via a pair of torque rods (like ailerons). My first inclination is to use CA hinges on the flaps, but on second thought, I wonder if three 1/8" Robart hinge points might not work better. On ailerons, I wouldn't worry about using CA hinges, but there is more force on the flaps.
IA
Hinge questions
I make my own hinges out of worldtec covering. These "hinges" are gapless, so no need to seal the gap later. I can let you know the procedure if your interested.
