Mamba Max Pro?
Mamba Max Pro?
Does anyone have some info on the Mamba Max Pro? Does it even exist? The heatsink appears to be different. The thread I got info from was started on another forum by an RCU member which had the small pic in it... Feel free to stand up. Credit goes to him I hope he isn't mad at me. I wonder if it will actually be rated for 4-5s. I hope. The regular Mamba Max is already enough for 1/8th conversions. This should be killer.
Is it just a new batch of the Mamba Max? MM Pro? Real? Fake? Who knows?
I hope this doesn't turn into another Monster Max thing with the release. That is if it even exists.
SK, BANGLADESH
RE: Mamba Max Pro?
I doubt very highly it would be rated for higher voltages that's what the MMM is for, and the MMM is cheap
they have been talking about a replacement for the regular MM, and they've been talking about removing the mini usb port from it as well
RE: Mamba Max Pro?
I've looked around, and the New MM Pro (or just new mm) will have a sidewinder type fan-friendly heatsink and will be rated for 5s lipo.
SK, BANGLADESH
RE: Mamba Max Pro?
if that's true, the MMM must have really been a failure
the MMM would only be good if you need to run 6S then, and plenty of good conversions can be done on 4 or 5s
RE: Mamba Max Pro?
I want to convert my revo using 4s. A regular Mamba Max will work fine, but it isn't rated for it. People run Mamba Maxes already on 5s. The new ones, by my understanding, have a high voltage cutoff. The old ones don't, and hopefully the ones coming out won't either.
RE: Mamba Max Pro?
Whoops. I knew it wasen't my fault. Just take out the space between the s and p. I wonder why it doesnt work...
http://www.castlespecialprojects.com/cs p_reversing_controllers.html
That's it. csp with a _ after it doesnt work. It turns into this: c
RE: Mamba Max Pro?
I just got a newsletter from Castle asking for Beta testers of the Mamba Max Pro. Apparently it has sensored and sensorless modes with a fan
RE: Mamba Max Pro?
The ROAR approval of the cm36s opens the current motors to a new market doesn't it ? Would castle make a sensored motor? Tekin has got a heap of bigger sensored (70 mm ) motors on the way.
RE: Mamba Max Pro?
I wasn't thinking sensored or ROAR approval, I mean more like a 1/10th scale 540 can size motor that runs as cool as the 'castle-neu' ones, designed with the same principles and all. 4-pole brushless is not going to the meet the specs for ROAR approval.
MI
RE: Mamba Max Pro?
I received the beta-test invite too:
http://www.magnetmail.net/actions/em...roup_id=322251
