Motor Sprays
RE: Motor Sprays
they're al about the same, i use the 'trinity dirtinator" spray and it works just fine. Some use other sprays, mind you all these sprays are downright smelly so use with adequate ventilation or you will go loopy on fumes [:'(]
ON, CANADA
RE: Motor Sprays
ORIGINAL: dkastil
the prob with break cleaner is it is verry toxic not like motor cleaner is not but break cleaner will eat threw plastic .
RE: Motor Sprays
actually the auto cleaners leave a resudue that other cleaners don't, if you want to use that stuff, fine, but lets not get into a fight over sprays [8D]
ON, CANADA
RE: Motor Sprays
Use what ya Like......But it's the same ****...
3Mâ„¢ Non-Chlorinated Brake Cleaner
Excellent for wetting out and flushing away grease, brake dust and fluid.Leaves no residue and helps eliminate disc brake squeal and chatter ,Does not contain harmful chlorinated solvents.
NON-CHLORINATED, Formulated to clean:
Brakes
Clutch parts
C.V. joints
Instantly Removes (Leaves no residue):
Brake fluid
Grease
Oil
Other Features:
Improves brake performance
Helps stop squealing
Does not contain 1,1,1, Trichloroethane, hydrocarbon propellants, or CFC's.
Brakes
Clutch parts
C.V. joints
Brake fluid
Grease
Oil
Other Features:
RE: Motor Sprays
Yeah it's always a better bargain to use non hobby brand stuff - they make a huge mark up and profit when all it is is some rebadged product you can obtain elsewhere.
I use about 90 - 100 psi of compressed air with one of those long skinny bent air gun nozzles. Put one of those rubber carb opening covers on before using the air gun though. It a also great way to blast debris out from around the glow plug because crud can fall in the hole when you remeove the plug.
Mineral spirits in a plastic spray bottle is good too.
