OMP - Ohio Model Products Support Forum Discuss products and get support from OMP. This forum is operated by the owners of OMP and your support questions or complaints will be handled as OMP deems appropriate.
Tetherite Landing Gear
Old 05-10-2009, 09:34 AM
hkilian
Default Tetherite Landing Gear
The attached photo shows my Yak 65 sitting on the medium size gear that I bought after having to bend the original Aluminum gear back into shape too often. The plane weighs a smidgen over 8 pounds and bends the gear to a point that the wheels look definitely cock-eyed. This is purely an aesthetic problem since the gear flexes beautifully on landing and shows no sign of wear or damage.
My question is has anyone epoxied a thin layer of carbon strip to the underside of the gear (tension-stressed) to reduce the flexing? This would be quite simple since the area is large and flat.
Herb
Old 05-10-2009, 10:43 AM
ThumbSkull
My Feedback: (57)
ThumbSkull's Avatar
Default RE: Tetherite Landing Gear
Yeah, make it stiffer so it will break instead of flex?
Sounds like it works perfectly. I wouldn't do a thing to it.
Old 05-10-2009, 05:44 PM
daveopam
My Feedback: (9)
daveopam's Avatar
If it bothers you go up a size on the Tetherite.
David
Old 05-11-2009, 02:40 PM
AFSalmon
AFSalmon's Avatar
Have not tried to epoxy any carbon on the bottom but some folks have used small gauge piano wire strapped on with gear straps. I have never had a need to do that though but my Yak was about 7 1/4 lbs and the gear is two years old and doing great.
