My 48" mono build
My 48" mono build
Old 08-14-2009, 04:53 PM
boatman12
Default My 48" mono build
This is the thread for my new boat build
Alright to start the engine will be this:
<a href="http://cgi.ebay.com/FeatherLite-Weedeater-Motor-Nearly-new_W0QQitemZ140339375065QQcmdZViewItemQQptZLH_Def aultDomain_0?hash=item20ace0ebd9&amp;_trksid=p3286 .c0.m14#ht_500wt_1101">http://cgi.ebay.com/FeatherLite-Weed...#ht_500wt_1101
<br type="_moz" /></a><br type="_moz" />
Old 08-14-2009, 08:15 PM
Tidnab
My Feedback: (51)
Tidnab's Avatar
Default RE: My 48
Although the Featherlite 25cc engine has been used in r/c boats,a Homelite would be a better choice as there are parts available to make it a little better.Things like water cooling jackets, manifolds,headers ,carbs and tuned pipes.Plus they can be modded more than the Weedeater brand engines.I run a Ryobi Homelite in a crackerbox and it's a great fun boat.I'm putting a full mod Homelite that was made into a full crank engine into a 54" deep vee and am not expecting any great speed out of the hull,but that engine was run in a Zippkits Easy vee and gps at 54mph,so I'm hoping for at least 45mph in the 54"hull.
Old 08-14-2009, 09:20 PM
rangerfredbob
My Feedback: (13)
Default RE: My 48
true the featherlights aren't a homie, but they are workable... carbs are obviously interchangable with anything, the linkages wil just need to be different, their downfall is the spring attached muffler, you'll have to figure something out with that. their other downfall is their very mild porting, they can be woken up with a little dremel work...
Old 08-14-2009, 11:38 PM
boatman12
Default RE: My 48
Alright thanks
I am building the hull from scratch
The zippkits are topriceyjust for some 1/8 wood
I have plans for the hull
Its a deep-vee
Just wondering how wideshouldI build the back of the boat?
I was thinking 13" Tell me waht you think?
thanks
Old 08-15-2009, 03:01 AM
martno1fan
martno1fan's Avatar
Default RE: My 48
Heres a set of Dougs plans for his new improved version of his woody ,use them and you will be right .This is the first time ive loaded these here so let me know if they work ok.Print them at 1.1 scale or 100% and tape all the parts together.
Mart
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old 08-16-2009, 10:38 PM
boatman12
Default RE: My 48
Thanks for the plans
Will post bulid pics
Have to go buy some wood
And I found a<span class="Apple-style-span" style="font-size: 13px; border-collapse: collapse; white-space: pre; -webkit-border-horizontal-spacing: 2px; -webkit-border-vertical-spacing: 2px; ">Different</span>engine How do think this one will work?
http://cgi.ebay.com/Homelite-Weed-Ea...#ht_500wt_1101<br type="_moz" />
Old 08-16-2009, 11:31 PM
rangerfredbob
My Feedback: (13)
Default RE: My 48
much more mainstream engine, lots of doable upgrades
Old 08-17-2009, 06:44 AM
Tidnab
My Feedback: (51)
Tidnab's Avatar
Default RE: My 48
Make sure it's not one of the newer 26cc Homelites.They have a slanted crankcase and make mounting a challenge and I've read rewiews from customers on the engine and they seem to be junk.
Old 08-17-2009, 09:08 AM
boatman12
Default RE: My 48
I got the plans allprinted and layed out
Going to the<span class="Apple-style-span" style="font-size: 13px; border-collapse: collapse; white-space: pre; -webkit-border-horizontal-spacing: 2px; -webkit-border-vertical-spacing: 2px; ">lumber </span>yard today
so i will<span class="Apple-style-span" style="font-size: 13px; border-collapse: collapse; white-space: pre; -webkit-border-horizontal-spacing: 2px; -webkit-border-vertical-spacing: 2px; ">probably </span>go with homelite engine
or shold I keep looking for a<span class="Apple-style-span" style="font-size: 13px; border-collapse: collapse; white-space: pre; -webkit-border-horizontal-spacing: 2px; -webkit-border-vertical-spacing: 2px; ">different </span>one?
<br type="_moz" />
Old 08-17-2009, 09:44 AM
rangerfredbob
My Feedback: (13)
Default RE: My 48
that's one of the last generation of the 25cc engines, the only better of the homelites would be if you could find a 30cc, which the new Ryobi engines with side carburetor and side exhaust (I think they are C30 or something) are 30cc homelites
I don't know how much you like tinkering, but there are a few things you can do to them. for one you will want a larger carburetor, the stock carb from a G230 or 260 would be a lot better than the stock homie carb, it shouldn't be too hard to find one that someone removed to upgrade... if you want to dig into the engine, the post in the exhaust port is pretty restrictive, but if you remove it you need to get a pinned piston ring, do a search on here for frank bowman, he makes custom rings and if you ask him for a pinned homie 25cc pinned ring he'll send you one for about $15. also on that style engine there is a hole above the exhaust port that goes to the muffler, run a tap in the hole and stick a set screw in it. That's all the general stuff
Old 08-17-2009, 12:45 PM
boatman12
Default RE: My 48
hi everbody
I bought all the wood
just wondering what i should use to glue all the parts
elemers wood gule or hot gule or something else?
<br type="_moz" />
Old 08-17-2009, 04:02 PM
boatman12
Default RE: My 48
hey mart
quick question about the plans
could you open up the plans
and see how long the rear transom is im getting 18"
but a page in the plans says it shold be 13"
Im am confused???
Old 08-17-2009, 07:09 PM
quicksilver78
quicksilver78's Avatar
Default RE: My 48
keep a eye on ebay theres a chinese motor going for 100 new already setup for marine
Old 08-18-2009, 02:28 AM
w3bby
Default RE: My 48
ORIGINAL: boatman12
...im getting 18'', but a page in the plans says it shold be 13''...
13", a little under really as the boat is 13" when skinned with 1/8" ply.
Have you printed the plan and measured, if not how are you measuring? When you print, do not scale to fit or anything else, print att 100% as Martin advised. I have the plan broken down into pages in pdf format, prints at 100% on both A4 (210 x 297mm) and letter (8.5 x 11"). If you want a copy then PM me an e-mail addy.
As regards glue, use a good epoxy, the longer the hardening time the better. Titebond 2 is also the business according to some prolific woody builders.
Old 08-18-2009, 05:18 AM
martno1fan
martno1fan's Avatar
Default RE: My 48
Yea as Webby says ,you can sometimes get good epoxy at good prices if you buy from a boatyard or similar and the cheapest way is to buy in bulk so the more you buy the cheaper it will be.Make sure its a slow setting one or if its one from a boatyard sometimes the faster one is the one to use as its usually 3-7 hr stuff' confusing i know' just be sure to ask .If bought in hardware stores or model outlets go for the slow ones they take arround 3 hrs to set and thats what you want.By the way if you go with a homelight use the Wa 167 walbro carb its the best one for a weedy motor for best performance,the 644 and 257 carbs are too big a bore usually unless you mod them a lot.
Mart
Old 08-18-2009, 01:05 PM
boatman12
Default RE: My 48
hello all thanks for all the info
yea i had printed the plans at 150%
got everything worked out!
about the prop
do you think this will be big enoguh
pics attched
<br type="_moz" />
ID:	1258568   Click image for larger version
Old 08-18-2009, 10:24 PM
jacob711
Default RE: My 48
that prop is no good, too small and plastic/carbon is no good
get a cheap 78mm prop from ebay
Old 08-20-2009, 12:04 PM
boatman12
Default RE: My 48
Could someone give me a link with a good prop i can buy?
i cant seem to find one<br type="_moz" />
Old 08-20-2009, 12:38 PM
mymammushouse
Default RE: My 48
ORIGINAL: boatman12
http://www.dasboata.com/index.php?cP...8239f25cc59eb6
Old 08-21-2009, 12:15 AM
jacob711
Default RE: My 48
none of them are big enough
try here http://cgi.ebay.com/Aluminium-Propel...4.c0.m14.l1262
Old 08-23-2009, 11:45 PM
dwr9
dwr9's Avatar
Default RE: My 48
You could also try here: http://www.zippkits.com/
Their prices are pretty good. Even if the seller says they are balanced I would check them. I have bought props that were supposed to be balanced and they weren't even close. Doug
