MT 80CC gas engine arrive now
The new MT80cc engine are here now , only 63oz weight are able to fit plane from 86 inch to 97 inch .
MT80
Displacement: 80CC
Output: 8+ hp
Weight: 3.85 lbs (1.78kg)
Stroke: 38 mm
Bore : 52 mm
RPM Range: 1200 to 7500
pls visit our website www.mtenginesusa.com
MT80
Displacement: 80CC
Output: 8+ hp
Stroke: 38 mm
Bore : 52 mm
My Feedback: (109)
RE: MT 80CC gas engine arrive now
I have several questions:
a. who does warranty work on your engines?
b. is the customer required to pay for shipping back to China for warranty service as some did on the MT57?
c. Are the engines being pre-ran before shipment to the customer to check for leaks as well as out of round crankshafts like some of the MT57's had?
thanks
thanks
Hi .PLANE JIM
I'd love to answer your question
1 a. who does warranty work on your engines?
we have distributor in USA to do the warranty works . www.mtenginesusa.com and www.swrcengines.com ( locate in TX )both distributor MT engine and do the warranty works, no need to send it back to China .
2 is the customer required to pay for shipping back to China for warranty service as some did on the MT57?
if you buy engine in USA. we nevery asking send the engine back to China and pay for the shipping fee. local distributor are able to handle all repair works for MT engines.
3 Are the engines being pre-ran before shipment to the customer to check for leaks as well as out of round crankshafts like some of the MT57's had?
leak problem are material . now we use Japen seal material and now leak problem any more. . engine are brand new without pre-ran because most customer are like brand new engine without any ran mark , it's hard to tell from customer that engine are just factory pre-ran or second hand . so we ship out only brand new engine now
pls email us if you have any question about MT engine .
Thank you
Tomy
Thank you
Tomy
Hi again.
Have any one tested the static thrust on this engine with various propellers.
Wondering if its possible to have this engine in a 2,6m Edge 540 Extreme composite with flying weight at approx 11.kg
So i hope this puppy can deliver 20kg ++ thrust with Ks Pipe
<span style="font-size: large;"><span style="font-family: Arial;"><span class="medium_text" id="result_box"><span title="">So someone made some test with this engine in airplane 33% size? </span><span title="">I want to know if the MT-80cc is able to take a 33% Yak Pilot-RC. Tanks!</span></span></span></span>
this is the video link from UK, MT-80 WITH TUNED PIPE TO FLY SABACH 342 FROM PILOT RC . http://www.youtube.com/watch?v=Vf7XMEtKPQI
<font size="4"><span id="result_box" class="long_text"><span>Sounds too good to be true. </span><span>At the end of the video we can see that there is only one servo per wing, which makes it possible to be 29%. </span><span>And if it was 36%, would weigh 13kg! </span><span>Any more video or data to provide us?</span></span></font>
i have a mt 80 just bought it less than a gallon of fuel tried to get repairs with no avail motor has locked up bad crankshaft no flaming but i think ppl should no what they r paying their hard earn money for it is really a good looking engine if u just had some way to talk to someone on these problems without a answering machine that never returns calls i have not found any kind of support
ORIGINAL: rebel1956
