JagdTiger Barrel
Old 11-03-2009, 06:54 PM
thomasjohnmurphy
Default JagdTiger Barrel
Does anyone know the correct length (1/16 scale) of the Jagdtiger barrel (from the base of the mantlet to the tip of the mussel. I'm looking to do some work on my 1/16 Jagdtiger (correcting the barrel length and upgrading to the RX 18 Board)
Old 11-04-2009, 10:54 AM
jwilliams3
Default RE: JagdTiger Barrel
I'm showing 9-11/16" where it stops at the front of the mantlet.
Old 11-04-2009, 10:56 AM
thomasjohnmurphy
much appreciated. I already have a a barrel (old graphite golf club).
Old 11-05-2009, 09:23 PM
thomasjohnmurphy
Here's my barrel. I will get it painted up tomorrow. It worked out well. A graphite golf club shaft cut to length and bored out to allow for an airsoft gun
Old 11-08-2009, 06:21 PM
thomasjohnmurphy
My finished barrel made from a graphite golf club shaft.
Old 11-08-2009, 06:41 PM
bowlman
ouch thats huge and scary to look at .
Jimmy
Old 11-08-2009, 07:03 PM
thomasjohnmurphy
Lol, if you think that's scary then look at this
http://www.youtube.com/watch?v=qFslF3Otzs8
Old 11-08-2009, 07:15 PM
bowlman
I like it makes my KT look like a kid .
Jimmy
Old 11-09-2009, 09:40 AM
karel47
karel47's Avatar
I've made him 33cm my jagdtiger barrel , aluminium weight about 33cm, the real barrel is what you see of the canon is 28cm. The barrel inside is exact 8mm just enough to put 88mm 1/16 munition in it , it just fit nomather with fabricant made them. I measered it from a 1/35 model took every piece of it from that model. the lenght is about it depends how yuo build the canon in, mine works with the multifunction set of the jagdpanther of tamiya, simply the best mark for RC tanks Two of mine were older then ten year, i have never got any throuble with broken parts etc...
Yes tamiya isn't cheap but deliver good quality, and all parts can be othered in a few weeks you have it.
Try and learn scratch is so fullfilling, when you see the endresult. Yes everyone has to remake some parts more than once, but you learn from your mistakes. No one can built at first model a perfect one, have fun, ask help and try and learn its rewardind at thime
karel
Old 11-09-2009, 09:42 AM
karel47
karel47's Avatar
correction my barrel weights 280gram
Old 11-09-2009, 03:53 PM
thomasjohnmurphy
do you have a picture of your barrel?
Old 11-09-2009, 04:35 PM
sevoblast
You mean this? Barrel is 24.5cm from front edge of mantlet at battery to muzzle, in other words ready to fire.
ID:	1310964   Click image for larger version
ID:	1310965   Click image for larger version
Old 11-09-2009, 04:40 PM
thomasjohnmurphy
Looks great.
Old 04-15-2010, 11:53 AM
karel47
karel47's Avatar
here are my pics
ID:	1418417   Click image for larger version
Old 04-15-2010, 02:33 PM
1sgt
ORIGINAL: thomasjohnmurphy
TJM,
How did you bore out the graphite club? I did use your idea ( using the graphite club for the Barrel) on my Pantiger. The barrel looks great, but now H an L has released a new Panther, I have slowed on the rest of the upgrades. One side of my brain says to do it for the experience and to say " I built that" The other side of my brain says put the $ into a new Panther. Ohhhh decisions, decisions.
Jim
Old 04-15-2010, 02:51 PM
thomasjohnmurphy
The Jagdtiger barrel is a graphite golf club (so it has a larger diameter and therefore the extra thickness of the graphite was fine and didn't need boring. I used an old fishing rod for my panther barrel. the fishing rod graphite is very thin and was great for that application (no boring needed)
