Mugen Sport-Seven?
My Feedback: (18)
NC
Mugen Sport-Seven?
Has any-one had or heard of a Mugen Sport-seven. It is a 4 wheel drive nitro powered truck I picked up at a sale that I am attempting to put together. I need some advice and or info on the engine installation.
My Feedback: (10)
RE: Mugen Sport-Seven?
I'm searching for you but I can't find a single thing on it. Are you sure that's what it is? I mean, and please don't be offended, is that what the manual or box or truck itself says? Is it 1/10 or 1/8th?
My Feedback: (18)
NC
Yea,that's what the box says. It is a 1/8 scale 4wd gas powered buggy. The diagram on the box macthes the truck and the kit # is 0502.29800. If I can find my camera I am going to post a pic. Give me a minute and I will try to locate it.
My Feedback: (18)
NC
Found my camera so I will try to post these pics. The problem I am having is spaceing the engine to the spur gear while keeping the bump start lined up. I am attempting to use a Team Orion Wasp 28.
My Feedback: (10)
Is there any way to adjust the motor mounts or are they solid? Try to take a few pics of the motor lined up and show the problem and maybe we/you can find a way to "rig" it to fit right.
My Feedback: (18)
NC
I think I know what my problem is. Don't think I am stupid but do they make different lengths on the crank-shafts on car engines? The Wasp engine I have appears to be shorter than the piture on the box.The base of the block is well behind the carb giving me a problem with both the flywheel hitting the carb and the shaft being too short. Am I making any sense?
My Feedback: (10)
You're not stupid and I wouldn't think that. You're asking questions, which is good. Yes there are different crank lengths with motors. Some have a longer one and some shorter. That's your problem as you found out. See this link: http://radiocontrol.wikia.com/wiki/E...ankshaft_types
Is that motor new? It looks like a nice motor but useless if you can't use it. PM me the details and I'll see if I can help you out.
the engine looks like it has a cut crankshaft.....please take pic of the engine shaft......... you may be able to reverse the center diff, then the gears would line up
ORIGINAL: hpidriver94
it looks like you can slide the motor farther forward
WY
Slide the engine forward. Where it sits now even if it had a flywheel it wouldn't line up with the flywheel slot for a bump box. Put a flywheel on and line up the cb and spur gear and I bet it would fit. If not get a taller clutch bell.
My Feedback: (18)
NC
I haven't bolted the engine down at all. The carb is hitting the triangle brace at the top. I have turned the carb every way I can and it still won't fit. I took the flywheel off to show the mount a little better. If I line up the bump start hole and the gears there is no room for the carb. I took the carb off and set the engine somewhat lined up so you can see what I mean. The only thing I can think of is if there is a type of engine with a longer nose and crank. Any guesses?
Location: San Diego but living in Dubai, UNITED ARAB EMIRATE
I don't know anything about this car but is the spur gear installed correctly? Looks to me like if you turn the spur gear around, it may all come together...
My Feedback: (18)
NC
I can't turn that around but how about a clutch bell that is extended beyond the tip of the crank. I have a schumaker that has a three speed. It has three gears on the clucth. If I could find one that is extended like that with only the one gear ring I think it would all line up.
I think a quick pm to this gent.... i8tweety
He's one bad putty tat.......but may have an answer or two for you.
Good luck with your ride, looks classic nice.
1 Post
The buggy was designed around an engine with a threaded crankshaft. The wasp engine has a pilot shaft crank.
This is an example of a threaded crankshaft:
This is an example of a pilot shaft crankshaft:
[IMAGE]http://www.osengines.com/parts/images/23602010.jpg[/img]
The buggy kit should have come with a clutch nut / pilot shaft like this:
Did the kit come with a flywheel? When installed, does it cover all the threads on the crankshaft? Please provide a photo of the engine with flywheel.
