RXT-1 Diff
Old 02-11-2010, 06:49 AM
morgy87
Default RXT-1 Diff
should there be any oil / grease in the diff's on the RXT-1 ???
Old 02-11-2010, 10:45 AM
ehroof
Default RE: RXT-1 Diff
Oil in the diff case (spyder gears)  I personally like 7 in the front 10 in the center and 3 in the rear, the ring and pinion gears should have grease on them.
Old 02-12-2010, 02:07 AM
sick6stang
What kind of grease goes on the ring and pinion gears? I changed out my differential gear oil, but failed to buy the grease for the ring and pinion. So what goes on them?
Old 02-12-2010, 03:22 AM
tylerjackson
I have used general purpose grease in mine with no problems at all.
Old 02-12-2010, 06:34 AM
bkfamily1
so did I - just plain old grease from the auto store - and it does not need to be packed full - just put a few pumps of grease in, enough to coat the teeth on both the ring and pinion gears
you should also take a look at shimming the pinion for good ring and pinion mesh if you have not already done so
Old 02-12-2010, 06:51 PM
tylerjackson
Forgot to mention about the shimming! The diff gears are already really good and will last quite awhile but with good shimming you wont have any problems from them unless of course if something else became out-of-whack first.
