G38 tuning help
Old 03-31-2010, 11:32 AM
stangman67
Default G38 tuning help
I bought a second hand extra 260 with a g38 in it and I finally got it to run yesterday after a few issues. It idles fine and revs nicely up until half throttle, after half throttle it acts starved and dies. I am new to gas engines and have limited experience with glow engines. It would make sense that the high speed needle needs adjusting. Do i need to lean it out or richen it up??
Zach (the gas newbie!)
Old 03-31-2010, 12:06 PM
Texastbird
Texastbird's Avatar
Default RE: G38 tuning help
That's probably all you need to do. The high speed needle is the one farthest away from the cylinder. About 1 1/2 turns is usually a good starting point.
Old 04-01-2010, 11:27 AM
captinjohn
Seems like my old G38 only needed the HI-SPEED needle open about 1/4 turn. Some carbs was made like this so you could not lean them out too much????
Capt,n
Old 04-01-2010, 12:21 PM
av8tor1977
av8tor1977's Avatar
Richen it up. If it won't richen up, rebuild the carb. The diaphragms get stiff after a while, and then won't work properly. It might also have a dirty filter screen inside the carb.
AV8TOR
Old 05-31-2010, 09:01 PM
bolkow
Had the same problem, bent the idle lever up VERY slightly, now idles and acclerates nicely.
Old 06-01-2010, 08:19 PM
bolkow
Needle valve lever.
