Rc10gt
Rc10gt
I need help getting this truck to run again I just bought a good running motor but i need the breakdown on the clutch what parts it takes i have the flywheel the little brass bushing that goes behind it the shaft that screws on to the crank the clutch bell and new shoes do the shoes take springs?
RE: Rc10gt
It is an os max 12 cv here is a pic of it http://s865.photobucket.com/albums/a...g&newest=1
RE: Rc10gt
hey freddy g 772 ,
just so ya know .
there is a whole section for stadium trucks , if you post there you would probably
get more reply's .
my gt10 has no springs on it from what i remember (been a while since i been in the clutch)
all other of my nitro's do though!!
just so ya know .
get more reply's .
RE: Rc10gt
So the two little white clutch shoes just slide in no springs? and is there some sort of drive gear that goes on before the flywheel? Thanks a bunch for all the help!
RE: Rc10gt
no drive gear , the flywheel usually has a tapered collar
that holds it onto the crankshaft, first the tapered collar then
the nut that has the bearing shank on it holds on the flywheel.
from the way i remember the shoes have no srpings on them ,
then goes the clutch bell, and the snap ring ,or some have a bolt
to hold it all together. if the shoes do accept a spring ,they will have
a groove through the middle of them . some have a little spring that
goes on the shaft that the shoes go on .but either way it would be
evident that there should be a spring.
RE: Rc10gt
that should be a good one .
i have the os .12 cvr , it will burn off the tires no matter where
i drive it . it is easy to tune ,and fun to drive (when you can control it)
RE: Rc10gt
I have the same little engine. It is a little power house. This one is old and tired and has seen better days. Here are some tips for ya. Follow the pics. Good Luck.
Make sure you use Blue LocTite on the nut and a C clip to hold the clutch bell in place.
RE: Rc10gt
there does not HAVE to be a throttle return spring,BUT......................................
i like to have one , i have had a run away my brother has had a run away
and my son has had a run away.
