600r starting
600r starting
MY 600R has sat for quite awhile and on the second start the starter sounds LOUD. I will be pulling the engine out when I get home, anything specifically to look out for/do?
I also had acceleration problems so it sounds like a calibration is due, hope that fixes all.
Regards
Bart
Regards
Bart
RE: 600r starting
2 things:
The O-Ring could be worn out and slipping: Replace or clean
The starter bendix assembly could also be out of alignment: Check alignment
You can crank the motor with 6-7.2V Pack.
Cheers,
B777
Cheers,
B777
