Zenoah G45 Won't Sustain Full Throttle
ON, CANADA
My G45 won't sustain full throttle for more than 10 seconds. Wat happens is that it will suddenly drop to half throttle. It is as if the high sppee needle stops working and is is running on the low end needle. Reducing the throttle for 5 seconds and the top end is back for the same 10 second period.
Adjusting both needles doesn't seem to make the problem go away.
Any suggestions would be appreciated
