Exceed G2 Raptor Disassembly Help
I Need Help, I have a G2 and crashed, messing up a main blade and bending the main blade screw and flybar. replaced these parts and went to power it up and before it stars to get off groud it spins CCW. I have discovered after reading post's on the subject that the tail rotor main gear is stripped. Holding the tail rotor with one hand and turn main rotor, results the tail rotor does not turn, only turn when there is no resistance to tail rotor. So I am disassembling the G2 and can not figure out how to get the sterring dowel out of the main shaft sleeve. I have the top half removed and I am to this point and stuck. I do not want to break or bend anything trying to get it out. Diagrams just give a layout of how they are aligned, it does not tell you how to do it. Please help my parts will be here soon. Ok after further inspection I ahve figured it out.....now my Raptor is completly disassembled and awaiting parts........
