HOTSHOT RE-RELEASE BUILD!
#726
RE: HOTSHOT RE-RELEASE BUILD!
Tamiya's inexperience in building it's first 4WD off road r/c car meant that this classic was built in layers. What I mean is you have to build it in sequence. A change of the receiver crystal in the buggy meant that you have to remove a lot of screws just to access it. Overall, it will take you at least a good 8 hours for you to finish, detail and run this kit.
#727
hELLO hotshot fans...Im starting to become a fan after reading this thread...
Did the Boomerang come out before the hotshot...and which car is better...??
#728
ORIGINAL: ElectricGuy007
#730
L=O-L... With that said .... if all r/c enthusiasts shared the same thought- that would put the aftermarket companies out of business.
#731
ORIGINAL: gulfstreamI
The Boomerang came out after the Hotshot, It represents Tamiya's continuing development of it's Four wheel drive off road vehicles back in the mid 1980's. For ease of maintenance, I would choose the Boomerang. That buggy was a simplified version of the Hotshot. The Hotshot IMHO, has a more scale off road vehicle look based on the the Fast Attack vehicle and Wild One 2WD buggies. The original Hotshot was simply ''over engineeered''. The current re -release version is slightly different compared to the original. It also duplicates the problems associated with the original: The annoying ''bump steering'' and the ''need to upgrade later'' mono shock system.
I think the Hotshot body looks good, whereas the boomerang body is all standard buggy looking.
I guess it's possible to put a hotshot shell on a boomerang isnt it?
#732
I think it is all good and fun to upgrade and tinker with RC.. no doubt about that.. all I was saying is that for a HotShot, I don't see the point of "upgrading" it, as you don't buy a HotShot re-re because you are after the performance. (get a modern 4WD buggy if you want that) So for me, so this is totally based on my personal opinion, is that if I am getting the HotShot, I just want to build and run this Tamiya legend.. to re-live the childhood, etc. All that kind of stuff.. as opposed to worry about how the suspension isn't the best, etc. That's the part that made HotShot unique.. !!
We will remember HotShot because of that funky suspension setup.. for stuff like TRF501.. the all out performance machine.. they get replaced with newer version every year.. they are less memorable.. !
#734
I have thought about what you said and I'll get a Boomerang instead of the Hotshot.
#735
Although I try to create confusion sometimes.. here's my modern buggy (J82) w/ Hornet paint job.. hee.. (yes, you can win races with this one.. !)
ORIGINAL: theibault
LB, I am so with you on that. When it comes to re-re's, I want the legend. I'm not trying to win the Worlds with a 20yo car. LOL
#736
It's possible only if you have the patience to ''trim'' certain parts of the Hot Shot roll cage and custom mount certain parts on a Boomerang chassis to make a ''Hot- Boomer'' buggy. Right out of the box I know you can't make them fit.
And post pictures in thier respective threads of course...
The frog will be better for me since you get like 2-3 different pinion gears with it.
Same thing with the boomerang, it comes with a couple pinons as well..
#737
new from Tamiya:
84265 Hotshot (2007) Metallic Special
finally...Gold Wheels!
http://www.tamiya.com/japan/products...2007/index.htm
#739
Yeah I had posted that re-release over in the other electric car forum before this...I guess it should have been in this classic forum...(btw, why does Tamiya do funny name changes with some re-re's!? )
I hope the gold wheels will be available separately!
#740
Resurrecting this thread! Anyone still around?
New here and returning to the hobby from a ~30 year hiatus. Back then my one and only was a HS2. Couldn't wait to see if they will re-re the HS2 so pulled the trigger recently on the HS. Hoping to receive it next week. But since I am coming into the hobby from scratch (parents threw away the HS2 a few years back as it had been in their garage..boo) I have to get everything else so things will go slow and much research is needed. Hoping to hear how the HS is doing the last few years! Thanks.
