TJT Turbine Direct Support Ask your questions about TJT turbine in this forum. All I-Jets related questions may be asked here if relevant or in the general jet forum.
TJT brotherhood
Old 11-11-2012, 05:06 PM
CARS II
My Feedback: (7)
CARS II's Avatar
Default TJT brotherhood
Ok
We know that this engine is in the exticion list, there are only a hand full of them left and that once in while one of us comes here looking for answers, help, parts. I'm starting this brotherhood to be able to exchange info to find solutions in a more efficient way.
Feel free to post any coments or info that may be of help.
I will start the list with myself on it as TJT brother # 1
Old 11-11-2012, 05:10 PM
CARS II
My Feedback: (7)
CARS II's Avatar
Default RE: TJT brotherhood
Here some info regarding parts, some of you may know this or not.
Mamba = TJT 3000, internal parts are interchangable.
I think we still can get service from RTI. I got me a thermo couple from Carlos some time ago.
Old 12-03-2012, 11:04 AM
LN-JET
LN-JET's Avatar
Nice initiative!
The early versions share many parts with the Artes Jg100.
I don't know for sure, but i guess that many parts also interchange from the Jet Central Super Eagle.
The compressor is the Garret T04B -22 will try to post exact part number later.
Bearings are the usual hybrid 608's.
Ngv and turbine are 66mm same as KJ66 parts.
Starter motor is a speed 400 6Volt type.
For those having Fadec from Gaspar Espiell, electronics and sensors are available from http://www.xicoy.com.
The most difficult parts for diy repair is the special bearing carriers and the shaft tunnel.
Regards
Lars
Old 12-03-2012, 11:43 AM
CARS II
My Feedback: (7)
CARS II's Avatar
Cool! welcome.
Thank you for all that useful info.
I have the AU 303 FEDEC, recently I had a problem with the engine quitting at idle and contacted Gaspar, he helped a lot, easy to work with, I changed the pump and moved the e-valves next to the FEDEC to eliminate any extension errors.
http://www.rcuniverse.com/forum/m_11..._1/key_/tm.htm
Old 09-14-2013, 07:32 PM
A10FLYR
A10FLYR's Avatar
Any one still flying these?
Old 09-18-2013, 12:08 PM
ron Sweeney
Default Tjt 300
[QUOTE=A10FLYR;11615971]Any one still flying these?Yes I still fly mine in a JMP phantom, that is, until recently, when my ecu died and the old F4 is now gathering dust in my garage. There is another 3000 in our club powering an SU27. Ron.
Old 09-18-2013, 08:37 PM
A10FLYR
A10FLYR's Avatar
I still have one NIB so that's 3 still around!
Old 03-07-2014, 10:44 AM
ITALY58
Hello guys,
I have also a TJT 3000, just changed bearings (new - 2 years ago), fuel pump (used a pump from JETCAT P80), and changed ecu, a new version of FADEC XICOY ELECTRONIC, with new display (3 wires and a plug like a JR servo plug) and all went GOOD !!!. (both changed 6 months ago)
It fly on a Boomerang XL with good response to trottle. (SORRY FOR MY ENGLISH).
Roberto "happy owner of TJT 3000" - Ciao to all.
Old 03-07-2014, 12:03 PM
ron Sweeney
Default tjt 3000
Originally Posted by ITALY58
Hello guys,
Hi Roberto glad to hear from you. Can you supply your ecu parameter and turbine run settings please, Regards Ron Sweeney,
Old 08-14-2017, 04:05 AM
Robertzr
Default TJT collector
Hi all,
I have three of them including one version where only 5 were made and 4 have survived.
Old 09-23-2017, 07:12 PM
CARS II
My Feedback: (7)
CARS II's Avatar
Mine still flying my Boomerang XL, had it flying two weeks ago, still running strong, I believe it is a 27 lbs one pushing a 42 lbs Boomerang on TO, these jets are big gliders so, no stress there.
Old 04-23-2018, 07:35 AM
b.mody
Hi,
My company has just purchased a used TJT 3000 from Australia and I am given the responsibility to make it operational. The engine we received comes with starter motor but rest is missing. I am looking for help:
1. Things I will require to make it run
2. Steps to follow to run the engine.
Any help will be appreciated. Thanks
Old 03-16-2021, 03:20 AM
Robertzr
Originally Posted by b.mody
Hi,
Have you managed to get your engine running?
Old 03-16-2021, 04:09 AM
CARS II
My Feedback: (7)
CARS II's Avatar
Ops!
I've seen this post till now, also curious to know.
Tks.
