Help! Dented Sirio BB Pipe!
I just got a new Sirio Big Bore Tuned Pipe for my Maxx and right at the end where the pipe connects to the manifold there is about a 3/16"-1/8" dent and its nicked in the same spot. Should i return it? If i install it will i lose any performance compared to a good Sirio BB Pipe?
RE: Help! Dented Sirio BB Pipe!
Plug the holes, fill it up with water, and put it in the freezer over night. The water will expand when it turns into ice, pulling out the dent.
Why did you make two posts of the exact same thing? http://www.rcuniverse.com/forum/best...1407537/tm.htm [&:]
Fill the pipe with water...plug the pipe...then put in freezer...do-not leave it overnight...just keep checking on it. from time to time...to make sure you have it where you want it....hope this helps.......mike
