TJT 3000 thrust?
My Feedback: (266)
TJT 3000 thrust?
Hello,
After the misleading thrust claims by Simjet (my "3000" puts out 25lb @ sea level @ 76 deg F.) I want to be sure I'm getting the motor performance I am paying for.
The TJT website (Performance specs ) shows 12.5Kg/33.6lb (wait,12.5KG = 33.6lb????) thrust rating ,but RCJI and others refer to this motor as a 27lb class motor.
What is the actual thrust I would measure TJT3000 at sea level and say,80F?
This is for a BV F-4 and I don't want to be flying at higher throttle settings if possible.
Jake Bruckler
Jake Bruckler
Thrust.
Hi Turbine Guy
The thrust level for the TJT-3000 is misquoted on our website and is scheduled to be fixed in the next edit. Its just a bug that slipped through he cracks... The ~34lb spec is the military specification, not for sale to the R/C community.
The correct specs are listed below.
Kelly
Note: as of Dec 2002 these figures have been revised to include continuous operation at 126K RPM @27.5lb. KW
TJT-3000 Specs are as follows:
Maximum Thrust:
27.5 lbs. (12.5 Kg) @126,000 - continuous operation
Residual (min) Thrust @ idle:
1.2 lbs. (0.55 Kg)
Max Permissible Shaft Speed:
126,000 RPM (max 2 minutes per engine run)
Max Continuous Shaft Speed:
120,000 RPM (entire flight)
Idle Shaft Speed:
32,000 RPM
Max EGT:
640°C
Case Pressure:
2.10 Bar
Fuel:
Kerosene, Jet A1
Start Fuel:
Propane
Oil:
Mobil Jet 2, Exxon 2380, Aeroshell 500
No substitutes, (2-stroke oil is NOT permitted)
Fuel - Oil Mix Ratio:
20:1 or 5% oil added to fuel volume
Fuel Consumption:
14 oz/min at 27.5 lbs thrust
Dimensions:
4.5 in. diameter, 9.5 in. length, 12.0 in. length w/electric starter motor
Weight (turbine/E-start/straps):
3.6 lbs. (1.65 Kg)
Turbine Wheel / NGV spec:
66mm Ø, manufactured by ArtesJet / TJT
Engine Color:
Polished aluminum casing, Red front cover
Polished aluminum electric starter
Kelly
Maximum Thrust:
1.2 lbs. (0.55 Kg)
Idle Shaft Speed:
32,000 RPM
Max EGT:
640°C
Case Pressure:
2.10 Bar
Fuel:
Kerosene, Jet A1
Start Fuel:
Propane
Oil:
Fuel Consumption:
Dimensions:
3.6 lbs. (1.65 Kg)
Engine Color:
TJT3000 specs & reviews
Heres a link to all the latest specs and products reviews for the
TJT 3000 EAGLE. http://www.TJT.bz/products2.php
