Tires
Tires
it's how hard they are. Like for foam tires that nitro cars should run. If you get the wrong shore then you won't have good traction. So basically it's how hard or soft the tire is.
Tires
the lower number is softer then the high numbers. A good set of tires really depends on the temp. the traction and many different things. I run 35's all around on mine but your climate may be different. Check with your lhs or the guys at the track. I'm sure they'll be glad to help you!
