View Poll Results: A poll
Voters: 25. You may not vote on this poll
CA Schme which one would you get
RE: CA Schme which one would you get
Look at the DR Hobbies extras. Same construction, no dihedral, and a scale like paint scheme. The only have 2-3% elevator coupling, about 1/3 that of the COMP ARF.
sorry 3D ONdaEDGE, for some reason i am scared of spending the same $ on a plane that i do not know versus one that i do and like.
if they were a few hundred less (i.e. $1k) then it would be worth the try.
My Feedback: (69)
AR
3wextra, the DR hobbies is made side by side with the comp arf. They are nothing more than CA airplanes with a couple changes specified by DR hobbies. I have had the comp arf extra and seen several of the DR planes. I like the DR a lot better plus with them actually being here replacement parts should be a lot easier to get. Plus, as mentioned, the wingtube is 10x better than the spars in the CA.
