Futaba 3pk
Futaba 3pk
Hi sorry to post this here, this seems to be a more active forum and hopefully I can get some useful responses here. I posted this in another forum, any help would be good.
"Hi, I have the 3pk radio with the 203HF HRS receiver. I dont have any
digital servos to run in HRS mode, so my question is can I choose PPM
modulation in the transmitter and have the HRS receiver operate on PPM
only and be able to use analog servos?"
RE: Futaba 3pk
You should be able to since the transmitter module should be the same. I have the PCM receiver and run my transmitter in both PCM and PPM. I use PPM when not using Futaba PCM modules, i.e. FM receivers such as Novak XXLs and the Futaba AM Conversion Module.
RE: Futaba 3pk
If you visit http://www.futaba-rc.com/radios/futj32.html and scroll down, you should notice that R203HF is listed as both FM and HRS modulation, while PCM uses the R113iP receiver. The manual is also downloadable at the same link if you need one to keep handy or just want a computer file manual.
By the way, I'm going to delete your other duplicate thread and move this thread to the RC Car Radio Equipment forum.
RE: Futaba 3pk
According to the manual you cannot use analogue servos with the HRS receiver. Whether or not if you set to FM only and it's safe is another matter.
PCM allows you to use analogue or digital servos.
RE: Futaba 3pk
ORIGINAL: Mad Wax
RE: Futaba 3pk
Tigger - in the 3PK you can slow the speed of the servo down but the tx rate is still high.
offspring - i don't think you can use the HRS mode on a PPM rx. i have tried by accident several times (switching between models with PPM rxs). but you can easily switch to PPM tx mode for all your PPM needs.
