Go Back  RCU Forums > RC Helicopters > Draganfly Innovations Products
Never saw it coming...
Draganfly Innovations Products Discuss all the Draganfly Innovations Products in this forum
Old 03-02-2007, 04:08 PM
SAVS
SAVS's Avatar
Default Never saw it coming...
The picture says it all [:@]
To see the rest of the show... http://www.nextnethosting.net/DF/Fla...hringhaus.html
Old 03-02-2007, 04:38 PM
flyingdutchie
Default RE: Never saw it coming...
Thats some wicked hands off hovering there ..Break anything?
Old 03-02-2007, 04:43 PM
13BRV3
Hi Denny,
It looks like the new battery got rid of the power loss problem, but now it won't come down at all
Thanks for the video.
Rusty
SAVS
SAVS's Avatar
ORIGINAL: flyingdutchie
I did not break anything but my pride. I had quite a gathering of college students just waiting for me to do just what I did.
Old 03-02-2007, 04:47 PM
SAVS
SAVS's Avatar
ORIGINAL: 13BRV3
Hi Denny,
Rusty
It was a battery and now that one is used only for the wireless receiver. I have to say I never saw the cable coming. It tumbled down the tree thank heaven or it would have been way out of reach. The branch looked funny wrapped around one of the rotors. You can see it took me awhile to get it down with my retrieving stick.[&:]
Old 03-02-2007, 07:14 PM
Sky High
SAVS, what was your location relative to the DF when that happened? If you weren't under it then I would say your spatial judgement or lack of depth perception caused that because you couldn't really tell how far away you were from those lines. I did that when trying to fly through some goal posts at that stadium where I usually fly. You just can't tell if you are on the inside or outside of the posts when flying perpendicular to your position on the ground. My rotors clipped one of the posts and you know what happened next. I'll have to post that video some time. That almost happened again at our larger baseball stadium but this time it was one of those 200 ft tall concrete light poles. I thought I was going to fly past it on the side facing me but the DF was farther out than I thought and when the DF dissappeard behind it, I realized I had flown past the outer side thank goodness and not directly into it. I have never tried flying past objects at that angle again. You can't go wrong if flying directly in or away from yourself.
Old 03-02-2007, 08:11 PM
SAVS
SAVS's Avatar
ORIGINAL: Sky High
SAVS, what was your location relative to the DF when that happened? If you weren't under it then I would say your spatial judgement caused that because you couldn't really tell how far away you were from those lines. I did that when trying to fly through some goal posts at that stadium where I usually fly. You just can't tell if you are on the inside or outside of the posts when flying perpendicular to your position on the ground. My rotors clipped one of the posts and you know what happened next. I'll have to post that video some time. That almost happened again at our larger baseball stadium but this time it was one of those 200 ft tall concrete light poles. I thought I was going to fly past it on the side facing me but the DF was farther out than I thought and when the DF dissappeard behind it, I realized I had flown past the outer side thank goodness and not directly into it. I have never tried flying past objects at that angle again. You can't go wrong if flying directly in or away from yourself.
I have to be lame here and say that even though I worked at that field for 4 months I never even noticed the cable hanging in the air. I saw it the same time the DF did. Lesson learned, get to know your surroundings prior to taking off. That and a gust of wind sort of blew me that way.
Old 03-02-2007, 08:15 PM
TheHindmost
You got some pretty cool video there before the, er, encounter! Actually, that part was pretty cool, too! Great music choice...
Glad to hear there wasn't any real damage!
Will
Old 03-02-2007, 09:05 PM
Sky High
ORIGINAL: SAVS
Yep, those thin wires blending with the background. So now we can use the phrase, you're as blind as a SAVS! instead of a bat, that is. You're lucky to get it back so easy look at what I had to do to get mine back from a 60 ft tree in [link=http://www.rcuniverse.com/forum/fb.asp?m=3746138]this[/link] thread. [>:] The good thing about landing in trees is that they break the fall really well with those springy limbs.
Old 03-02-2007, 09:48 PM
peterrbb
Well done SAVS, cool video
Old 03-02-2007, 09:51 PM
peterrbb
p.s . Take offs optional, landings mandatory
Old 03-02-2007, 10:09 PM
AeroRecon
That was pretty slick!
Noticed the UNC reference...I will be down that way from Fredericksburg, VA for a class next weekend for 4 days. Maybe we can hook up and fly.
Great part of the video was the official aerial obstacle removeal tool....a bigger stick!
Allen
Old 03-02-2007, 10:25 PM
SAVS
SAVS's Avatar
ORIGINAL: AeroRecon
Great part of the video was the official aerial obstacle removal tool....a bigger stick!
Allen
Boy could I use some experienced help! I have access to the new UNC football fields (since we just built them) and need to get some good aerial video/stills of the fields. If the weather behaves and you have the time some help would be great! I'll PM you with my contact info...Denny
Old 03-03-2007, 05:58 PM
zBigBadWolf
zBigBadWolf's Avatar
Is this what I have to look forward to when I finally get mine higher than 5 feet off the ground?
Old 03-03-2007, 08:25 PM
SAVS
SAVS's Avatar
ORIGINAL: zBigBadWolf
This and sooooo much more! I am finding out that slow and easy is working for me. Take a Valium and take your time each and every time you go out. When I finally learned that I can not become a pilot over night I started getting better. I was way frustrated when I first started you would not believe it. This is not easy but as I get better I feel more confident (then you get the great action videos! CRASH)
Old 03-04-2007, 04:12 PM
AeroRecon
My bro-in-law just got a Helimax Axe CP and it's kinda cool. But I like my DF better. Of course I was the star when he handed me the Tx and I could hover right away.
We have been flying my DF in the basement all day long with my DF on the tether and hooked to one of those small yellow porta-starter units. Works great!! Been getting about two hours flight time out of it...stopping every fifteen or so for cool down. But I guess I am getting off topic....so that's all.
Allen
Old 03-04-2007, 09:49 PM
Sky High
Yep, AeroRecon has probably flown over more tall trees than any of us. My DF has been trapped in trees twice so I try my bestest to not fly over them.
