guestions
Old 04-08-2007, 05:36 PM
foltzy90
Default guestions
i got a tmaxx with a trx2.5 everything is stock on it, the steering wont turn as fast as it did when i got it i was wonderin if its the servo or the servo saver,
also my engine stalls after 10 mins and is less then 250 degrees and wont start for like 5 mins... and ideas of what i can do?
Old 04-08-2007, 05:44 PM
foltzy90
Default RE: guestions
forgot to ask, can u guys tell me a website to get good upgrades for a 2.5r and aluminum parts
Old 04-08-2007, 05:45 PM
Steve455400
for your steering did you try new batteries? cause if you have batteries in them that have been used a little it will slow down you steering servos. Also for your motor over heating you might want to richen the high speed needle a little and lean the low speed needle depending on your idle if your idle and how it runs your other option would to richen the low speed needle a little but you might want to give more details on your motor how it's reacting and the performance your getting stuff like that so it's easier for us rc enthusiasts to figure out your problem but I hope the info I gave you helps.
Old 04-08-2007, 06:34 PM
foltzy90
ok, my engine will run a little sluggish i got fine blue smoke from exhaust, the temperature never goes above 250, adn it just cuts out and wont start for like 5 mins
as for my steering i put new batteries in it but it still has poor steering i noticed that the servo saver is a little dinged up adn bent should i replace that?
Old 04-08-2007, 06:53 PM
Steve455400
yea that might be your servo saver for your stering problem for you engine problem it seems that you need to richen the low speed needle and lean out you high speed needle try that once if you still get poor performace from your engine start from factory setting. factory seting's are turn your high speed needle right till it's snugg and back it out 4 turns and go from there.
Old 04-08-2007, 07:36 PM
jarett 92
jarett 92's Avatar
also id suggest you do not buy aluminum parts...u might think they are good because they are strong but as soon as u have one bad wreck then its just one big twisted ball of aluminum
Old 04-08-2007, 08:28 PM
BANDGEEK1
i got a traxxas rustler not long ago, its used, but i also got a t-maxx that works from the same guy. the rustler doesn't work, the engine wont start. it gets gas, and the glow plug is good. the electric starter works also. any ideas on how to get it to start
Old 04-09-2007, 02:44 PM
foltzy90
i do have all my needles set to factory, i got lsn flush hsn 4 turns out adn idle screw so slide is 1mm but it still doesnt work
Old 04-09-2007, 02:51 PM
mrbig6901
Im considering buying a 1.5 t maxx any suggestions
BANDGEEK1
yesterday i fliped my t-maxx in the mud, and even though i cleaned it, it still wont start again. i got the faintest start, but it shuts off when the gas hits the carburator.
Old 04-09-2007, 02:52 PM
mrbig6901
That sux
Old 04-09-2007, 02:55 PM
BANDGEEK1
the t-maxx is a good truck, ive had mine for about a week, but it hadn't run for about a year. it starts, but now that i've driven it in the mud i have to work with it. the t-maxx is good, but make sure if you drive it on a ramp, or somewhere really bumpy, check to see if the reciever is still functioning, otherwise you'll lose control of it.
Old 04-09-2007, 02:59 PM
mrbig6901
So evin the old 1.5s are good???Im payin $150 canadain for it???
Old 04-09-2007, 03:07 PM
mrbig6901
I dont wanna get ripped !!!
Old 04-09-2007, 03:19 PM
Mz
Mz's Avatar
150 Canadian is about 130 us...
is the t-maxx new or used?
Old 04-09-2007, 03:33 PM
mrbig6901
Well used..It looks beat...but it is RTR
Old 04-09-2007, 03:42 PM
mrbig6901
other than motor is there ne difference between the old 1.5 and the new 2.5???????
Mz
Mz's Avatar
i wouldn't do it...
just save up and get a new t-maxx 2.5
Old 04-09-2007, 03:43 PM
mrbig6901
Yha i seem to have a problem with that saving thing???
Old 04-09-2007, 03:44 PM
Mz
Mz's Avatar
yea... wider arms and stuff. not too sure about other stuff im sure theres other minor upgrades though
