EZ wires
EZ wires
Hi the EZ start wires that go to the little electric motor the red and the black ones they keep falling off when I am driving and they get caught in between the spur gear and the pinion gear, is there any way that I can stop them from falling off?
ON, CANADA
RE: EZ wires
I assume there are little no solder leads that slip onto the motor tabs? You can tighten those with some pliers so that they dont pull off as easy but the best way is to solder them.
