HEAD KIT
HEAD KIT
does any one make a head kit with interchangeable dome's for a 260 pum so you can change the compression ratio so you could run vp 110 octane fuel? also whats the stock dome on a pum? is it 13-1 if so a dome like 15-1 would able us to run higher octane fuels.
RE: HEAD KIT
Depending on your port timing your zenoah can be from about 9;1 up to 13;1
so you really dont need to have changable head dome
Raising compression you will not notice a huge increase of power it brings torque up slightly but also increases heat from higher combustion temps
Plus to run a high octane fuel you will need to have your static timing adjustable (more timing)to reap the benefits as the higher the octane the slower the ignition an burn rate
