Here is a few more.
It's nothing special.
specs are
AX10 based Edge tuber
normal ESC for it is a Tekin FX-R and CCBECpowering a Integy 75 turn lathe motor
Hitec 7955 servo
full droop using stock shocks medium TCS inside springs 100wt Losi shock oil
East end Machining double triangulation delrin skid plate
hand made solid 1/4 inchaluminumlinkswith large revo rod ends screwed directly to the links with 5mm threads
BTA steering with aluminum Cs Vanquish high clearance steering knuckles
Losi comp claws mounted on RCFWD aluminum rockstar beadlocks 17 oz total each front tire 14 oz total each rear tire
I don'thave a scale that weighs more than a poundso I don't know what thecrawlerweighs
