sikk timing on a zenoah
hallo guys. i am running a 25.4 sikk motor and are happy with its performance buttt i had my off days[:@] due to some failure issues. i bought my self a standard zenoah and want to start toggel it a bitt . how much performance should i get if i do coppy the timing from the sikk and cut the zenoah the same. we do figure m coarse racing and i do need a motor with good throttel response. if i go with exhaust 178*and the inlet 155* what hp rating should i have. any suggetions is welcome.
RE: sikk timing on a zenoah
http://www.modelgasboats.com/Magazin...ngine_Porting/
just do the same as that and it will run better than the cy engine
ORIGINAL: wet a wild
* Do use the link provided [:@] ..... You will be quite happy with the results
