CYCLONE 88" EXTRA 330l WITH RCGF 62CC ENGINE QUICK BUILD
#427
MO
RE: CYCLONE 88
Just working on tons of foamys right now for indoor flying, as far as Giant scale, I'm gonna be purchasing one next month... I'm thinking about going 35%, but I got all this stuff for 30% planes around so I might just go that route.
#428
RE: CYCLONE 88
Hello TJ,
<span class="long_text" id="result_box"><span closure_uid_qlurlw="229" title="Meu nome é Julio moro no Brazil." style="BACKGROUND-COLOR: #fff">My name is Julio I live in Brazil. </span><span closure_uid_qlurlw="230" title="Sou fabricante das hélice de madeira de alta performance a 19 anos" JC.super props "." style="BACKGROUND-COLOR: #ebeff9">I am a manufacturer of wooden propeller of high performance to 19 years "JC.super props."
</span><span closure_uid_qlurlw="231" title="Vc disse que achou estranho a medida hélice 23x7rsrs." style="BACKGROUND-COLOR: #fff">You said that it was very strange to measure propeller 23x7. </span><span closure_uid_qlurlw="286" title="Eu desenvolvo e fabrico qualquer medida (picth ou diâmetro)." style="BACKGROUND-COLOR: #fff">I develop and manufacture any measure (picth or diameter). </span><span closure_uid_qlurlw="319" title="Se vc precisar de algua hélice, entre em contato comigo ok">If you need someone propeller, contact me ok
</span><span closure_uid_qlurlw="356" title="e-mail: [email protected]" style="BACKGROUND-COLOR: #fff">Email: [email protected]
</span><span closure_uid_qlurlw="393" title="MSN: [email protected]" style="BACKGROUND-COLOR: #fff">MSN: [email protected]
</span><span closure_uid_qlurlw="404" title="aguardo seu contato," style="BACKGROUND-COLOR: #fff">I await your contact
</span><span closure_uid_qlurlw="413" title="abraço" style="BACKGROUND-COLOR: #fff">hug
</span><span closure_uid_qlurlw="418" title="Julio" style="BACKGROUND-COLOR: #fff">Julio</span></span>
#429
My Feedback: (42)
RE: CYCLONE 88
Julio makes good props. I am the exclusive importer for the USA and have 23x7 and 23x8 in stock along with many other sizes.
www.wrongwayrc.com
What we have found with the 23x7 is a couple more rpms than the 23x8 so you get the benefit of the larger disc giving a bigger air flow area over the control surfaces with a little more pull out. If you 50cc is very strong you stand a chance of having more prop noise, that is the downfall. In that case I might go with the 23x8.
Way back when... on my first 50cc I had a 22x8 and 23x8 prop and liked what each would do but wanted best of both...IMO that the 23x7 can be just that.
Hey Tim, your 25x7 went out yesterday.....let me know how it works on that other engine.
www.wrongwayrc.com
#431
RE: CYCLONE 88
ORIGINAL: Richard D Bahmann aka/Wrongway
www.wrongwayrc.com
www.wrongwayrc.com
Got any Pics of the prop
#434
My Feedback: (42)
RE: CYCLONE 88
This is the 23x8
The wood is different. This is Pau Marfim (translates to Ivory Wood) and is more dense/stronger than birch. Wood will still break but these props can take a certain amount of hangar rash/ground strikes before they go.
Here is the 23x7 on my now sold 88 EF Yak, the plane was near 18 lbs and I did not know it at the time but the rings had a problem so power was not all there.
http://www.youtube.com/watch?v=oKc4hekLPdE
#435
RE: CYCLONE 88
ORIGINAL: skip1320
Great combo,did nothing but hinges and check glue joints 16.5 dry DL w/s/line
Dude Skip, I just bought this plane, its gonna show up @ my house in a day or two. 16.5 lbs is great, what exactly do you have in it for equipment. I see the DL and the pitts muffler, what about batteries and servos ? Hows it holding up ?
Thanks Dude !
#436
MO
RE: CYCLONE 88
ORIGINAL: Crash-n-Burn
Thanks Dude !
ORIGINAL: skip1320
Thanks Dude !
#438
RE: CYCLONE 88
Hi guys I am building the Peak Models 50CC edge 540 T check it out:
http://www.rcuniverse.com/forum/m_96...tm.htm#9635842
Also its over on FG's website under Git-r-Done Giant Scale
#439
MO
RE: CYCLONE 88
OK guys, I have purchased the plane that I'm going to build next... Its the GoldWing RC 88" Yak-55SP V2 http://www.goldwingrc.com/en/ProductView.asp?ID=159
it can be purchased from a few places... U.S. www.Topdawgaviation.com formerly Dietrich aircraft, or U.K. www.Globalrc.co.uk
Also there are the older versions floating around out there... the Dawghouse yak-55 or the peakmodel yak-55.
If you are familiar with the OMP 50cc Yak-55SP made by EG aircraft then then you should be slightly familiar with the construction of this plane. They are very similar in design, just a few changes in the motor box and the way the inside is laid out. Also it seems as the canopy on the OMP is not as bubbly as the Goldwing one.
The color scheme I picked is close to the Comp ARF Yak-55SP butterfly scheme (just a different color) http://www.carf-models.com/public_ca...riant&proId=38
(oh yeah, Dan Check out the way the canopy is separated on the CARF yak)
I like this one because the colors match the extra 330L so now I don't have to repaint the pilot if I put him in the yak!
Once I start the build I will post a link to the thread.
Oh, and the engine is a DL-55v2 I bought the plane and engine as a combo.
#440
MO
RE: CYCLONE 88
I finally got around to the build, this should be a quick one as the plane is 75% pre done... http://www.rcuniverse.com/forum/m_9669386/tm.htm
