Rc10gt
Old 04-20-2010, 04:33 PM
FreDDyG722
Default Rc10gt
I need help getting this truck to run again I just bought a good running motor but i need the breakdown on the clutch what parts it takes i have the flywheel the little brass bushing that goes behind it the shaft that screws on to the crank the clutch bell and new shoes do the shoes take springs?
Old 04-20-2010, 05:53 PM
quietnas1
Default RE: Rc10gt
The clutch on GT for the most part does not use a spring. What type of engine did you get?
Old 04-20-2010, 06:03 PM
FreDDyG722
Default RE: Rc10gt
It is an os max 12 cv here is a pic of it     http://s865.photobucket.com/albums/a...g&newest=1
Old 04-20-2010, 06:15 PM
rcslsafut
rcslsafut's Avatar
Default RE: Rc10gt
hey freddy g 772 ,
just so ya know .
there is a whole section for stadium trucks , if you post there you would probably
get more reply's .
my gt10 has no springs on it from what i remember (been a while since i been in the clutch)
all other of my nitro's do though!!
Old 04-20-2010, 06:17 PM
FreDDyG722
Default RE: Rc10gt
So the two little white clutch shoes just slide in no springs? and is there some sort of drive gear that goes on before the flywheel? Thanks a bunch for all the help!
Old 04-20-2010, 06:23 PM
rcslsafut
rcslsafut's Avatar
Default RE: Rc10gt
no drive gear , the flywheel usually has a tapered collar
that holds it onto the crankshaft, first the tapered collar then
the nut that has the bearing shank on it holds on the flywheel.
from the way i remember the shoes have no srpings on them ,
then goes the clutch bell, and the snap ring ,or some have a bolt
to hold it all together. if the shoes do accept a spring ,they will have
a groove through the middle of them . some have a little spring that
goes on the shaft that the shoes go on .but either way it would be
evident that there should be a spring.
Old 04-20-2010, 06:27 PM
FreDDyG722
Default RE: Rc10gt
YEP I have it all THANKSSOOOOMUCH!!!!!
Old 04-20-2010, 06:45 PM
FreDDyG722
Default RE: Rc10gt
Thanks again but do you think the motor i bought will be a good match?
Old 04-20-2010, 06:53 PM
rcslsafut
rcslsafut's Avatar
Default RE: Rc10gt
that should be a good one .
i have the os .12 cvr , it will burn off the tires no matter where
i drive it . it is easy to tune ,and fun to drive (when you can control it)
Old 04-20-2010, 06:58 PM
FreDDyG722
Default RE: Rc10gt
lol thanks man can't wait to get her finished!
Old 04-21-2010, 01:06 PM
FreDDyG722
Default RE: Rc10gt
Is there supposed to be a throttle return spring?
Old 04-21-2010, 04:55 PM
quietnas1
Default RE: Rc10gt
I have the same little engine. It is a little power house. This one is old and tired and has seen better days. Here are some tips for ya. Follow the pics. Good Luck.
Make sure you use Blue LocTite on the nut and a C clip to hold the clutch bell in place.
Old 04-21-2010, 06:20 PM
FreDDyG722
Default RE: Rc10gt
Thanks helped alot I'll make sure to use blue loctite
Old 04-21-2010, 07:48 PM
rcslsafut
rcslsafut's Avatar
Default RE: Rc10gt
there does not HAVE to be a throttle return spring,BUT......................................
i like to have one , i have had a run away my brother has had a run away
and my son has had a run away.
Old 04-21-2010, 07:51 PM
rcslsafut
rcslsafut's Avatar
Default RE: Rc10gt
here is what a run away COULD LOOK like !!!!!
it was not good!!!!! the truck was about a month old and only had about six or seven runs on it
ID:	1422377   Click image for larger version
Old 04-21-2010, 08:46 PM
FreDDyG722
Default RE: Rc10gt
DANGGG, I think I am gonna take it easy for a while with mine!
